Problem with Plywood
Forum topic by todd4390 posted 08-10-2014 06:28 PM 961 views 0 times favorited 4 replies Add to Favorites Watch
View todd4390's profile
todd4390
136 posts in 1372 days
08-10-2014 06:28 PM
So I built a window seat using birch ply from a big box store and when I started sanding it with 150 grit paper I got a few areas like this where the top veneer started peeling away. I pretty much stopped sanding to prevent further damage and was going to leave it as is because we are putting a cushion on the bench that will cover this but after priming I decided it was going to bother me if I didn’t fix it. Does anyone have any recommendations for filling these areas in and smoothing it out? Looking for something fairly easy and quick if possible.
View bondogaposis's profile
bondogaposis
4599 posts in 2255 days
#1 posted 08-10-2014 06:33 PM
Epoxy.
-- Bondo Gaposis
View Yonak's profile
Yonak
986 posts in 1425 days
#2 posted 08-10-2014 06:39 PM
Epoxy or Bondo wood filler will work. Both can be tinted with powdered pigments.
View NoThanks's profile
NoThanks
798 posts in 1433 days
#3 posted 08-10-2014 07:14 PM
Squeeze as much glue into it as you can first, tape it down and let dry, then fill it and sand it. Bondo would be my choice since your painting it.
-- Because I'm gone, that's why!
todd4390
#4 posted 08-10-2014 08:08 PM
Thanks for the advice
