Cutting small & precise pieces
Forum topic by GJK posted 08-10-2014 03:48 AM 899 views 0 times favorited 2 replies Add to Favorites Watch
View GJK's profile
GJK
27 posts in 1385 days
08-10-2014 03:48 AM
Topic tags/keywords: question joiner table saw beech
I would like to make a larger version of the after-shower mat, shown below, that is made of European beech and is approx. 23.5” x 17.75” x .75”
The piece I would like to make would be larger (approx. 40” x 23.25” x .75”) and for another room.
I now have a piece of European beech:
from which I would like to cut 16 slats each 40” x 1.25” wide x .75” deep
To do that, I have removed about .5” from both faces to clean up the small holes and also trim off the waste on the side and I have cut the board in half to create two 40” long boards. I now need to:
1. Cut two slices each 5” wide x .75” deep from each.
2. Then cut each of the four pieces into four equal strips 40” long x 1.25” wide x .75” deep.
Thus, there would be 16 equally sized pieces 40” long x 1.25” wide x .75” deep.
Is is feasible to make these cuts? with what equipment?
I would then need router to shape edges.
-- Gary, Washington, DC
2 replies so far
View bobasaurus's profile
bobasaurus
3448 posts in 3182 days
#1 posted 08-10-2014 04:03 AM
Don’t forget the kerf of the cut in your calculations. If you want 1.25 wide, each cut will really take (1.25+kerf) from the board, so 5” exactly isn’t enough for four of them.
I just used my table saw to cut 40” thin strips for my cutting board and it worked well. I would recommend the same after dimensioning (need a flat face and jointed edge for the TS).
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View OldWrangler's profile
OldWrangler
731 posts in 1593 days
#2 posted 08-10-2014 04:18 AM
Be careful with finishing this. A slippery surface and wet feet is an accident waiting to happen.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
