Corner braces - required?
« back to Joinery forum
Forum topic by CDuarte posted 08-09-2014 07:56 PM 1227 views 0 times favorited 10 replies Add to Favorites Watch
View CDuarte's profile
CDuarte
3 posts in 1255 days
08-09-2014 07:56 PM
Topic tags/keywords: tables corner braches braches
Hello all,
I have built several tables all types and would you like your input about corner braces.
Are they required?
When should they be used?
I have built tables with and without…
Thank you,
10 replies so far
17193 posts in 1725 days
#1 posted 08-09-2014 08:21 PM
Do you mean corner braces in the frame underneath? If so I would say you don’t need them since the top should keep the frame square.
View crank49's profile
crank49
4028 posts in 2840 days
#2 posted 08-09-2014 09:06 PM
Are you stretchers or aprons attached to the legs with tenons?
If so, you need NO braces.
CDuarte
#3 posted 08-10-2014 12:11 AM
Good afternoon all,
Thank you for taking the time to reply, I do use tenons on all my corners so I have not used corner braces on several projects.
I appreciate the feedback and always looking for tips.
View wseand's profile
wseand
2796 posts in 2911 days
#4 posted 08-20-2014 03:48 AM
Here is my input. I consider the legs/skirts and top as two separate pieces. Meaning the bottom should be able to keep its square and stability on its own. I prefer to have the top be able to move or shift separately from the bottom to compensate for the movement of the wood.
That being said if the bottom can’t keep its stability on its own then I would use corner braces. I prefer to always use corner bracing just for the fact that adding the braces doesn’t take much more time and the stability they add far out ways the time they take to put in place.
View Aj2's profile
Aj2
1219 posts in 1667 days
#5 posted 08-20-2014 04:01 AM
I use corner braces if there is no lower stretcher .It won’t take much to break the jointery at the apron , from people kicking the leg at the bottom.Loose tenons mortise and tenon can still break free.But if there’s no time or the budget is tight I understand .Aj
-- Aj
wseand
#6 posted 08-20-2014 03:21 PM
I agree AJ you need some sort of support, I want my tables to last for a long time, so what ever that takes. No mater how spectacular your M&T is, eventually glue fails and sometimes way before you expect it to.
If I think about it there is a lot of variables that makes this question hard to answer for every table. You really need to answer this question in the design phase of the table. Obviously the larger the table the more support you will need.
A great question though makes me remember the little things are important to the over all design.
Bill
CDuarte
#7 posted 08-20-2014 05:09 PM
Good morning all,
Thank you once again, I really enjoy the design and building so I welcome all input. The table I am building is just for myself and will sit 4 to six (maybe a little tight)
I loading a picture…don’t make too much fun LOL
wseand
#8 posted 08-22-2014 04:28 AM
Real nice looking, as long as the people aren’t as big as me you should be good to go..
View Rick_M's profile
Rick_M
10800 posts in 2249 days
#9 posted 08-22-2014 08:34 PM
Bill
- wseand
That’s why I pin all my M&T joints from the inside of the legs. But I’ve never had a glue failure.
As for corner braces, I’ve never used them on the 6 or 7 tables I’ve built.
-- http://thewoodknack.blogspot.com/
wseand
#10 posted 08-25-2014 07:04 AM
Hey Rick,
Well I am glad you never had a glue failure and I like the idea of pinning them in.
I have recently done many refurbishing’s and every one had glue failure everywhere. The only thing holding them together was cross bracing and or corner bracing.
Anyways, use them or don’t use them it really doesn’t matter in the whole scheme of things. I say the better support you have the longer it will last.
Bill
