Buying -Like new cond. 10" Craftsman bandsaw
Forum topic by Eastern posted 08-08-2014 01:03 PM 887 views 0 times favorited 10 replies Add to Favorites Watch
View Eastern's profile
Eastern
17 posts in 1355 days
08-08-2014 01:03 PM
Picking up this bandsaw for 85.00…...
Okay deal?
10 replies so far
View bigblockyeti's profile
bigblockyeti
4982 posts in 1625 days
#1 posted 08-08-2014 01:16 PM
I bought a similar Ryobi (9”) and got it for only $30 and wouldn’t have been willing to spend any more. Does it still have any warranty? If not, half that would be a deal.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2754 days
#2 posted 08-08-2014 01:25 PM
Depends on what you’re planning, many go for the 10 and realize they need more to resaw, why is this guy selling? At $85 you’re not too far away from the $120 mark that a lot of 14” go for on CL, but, if you’re primarily working with small stock, or know that you may keep it to run a 1/4” blade and eventually buy a bigger one to load with 1/2” to 3/4” blades to resaw with then I’d start the haggle at $50, and see what he has to sweeten the deal, misc. blades, jigs etc.
View knotscott's profile
knotscott
7872 posts in 3280 days
#3 posted 08-08-2014 01:39 PM
The Cman 10” has a cast iron table, steel body, decent cutting height capacity, cast aluminum wheels AFAIK, and generally has a good reputation….it’s in a bit different league than the plastic/aluminum units from Skil, Delta, Ryobi, etc. Lots of folks who have big resaw bandsaws bought them for curve work. $85 isn’t too bad, but I’d be inclined to offer $75 just in case they’ll take it.
Eastern
#4 posted 08-08-2014 01:46 PM
Hmm….I thought I was getting a pretty good deal since the saw retails for 170.00 on sale. I’m glad I asked about it. He said he made wooden pens with it an just doesn’t have time for it anymore and it’s in like-new condition. He also said he doesn’t know where the fence is , a 45.00 item ( I looked it up).
I really don’t have the room for anything but a small 10” saw – as much as I’d love a 14” saw.
View paxorion's profile
paxorion
1107 posts in 1950 days
#5 posted 08-08-2014 01:49 PM
This Craftsman bandsaw appears to be the Rikon 10-305 clone. Sounds like a pretty good deal to me.
-- paxorion
ChefHDAN
#6 posted 08-08-2014 02:27 PM
If it’s a clean low mile unit, and you can’t fit a 14” then pull the trigger and get to makin’ sawdust, like Pax says it’s a Rikon clone and most likely comes from the same factory with a different badge, since CS doesn’t really make anything themselves, good luck with the dickering and be sure to post pics once you get it home!
View Steve Peterson's profile
Steve Peterson
365 posts in 2987 days
#7 posted 08-08-2014 05:59 PM
I was going to say that I paid $99 for a brand new Craftsman bandsaw, but that was many many years ago and it does not have anywhere near the same features that yours has.
$85 sounds like a good deal for that saw. You may find that the 1/3 hp motor is a bit weak for resawing. It should be great for quick cuts in 1” or thinner material. It should be a great 2nd saw if you decide to upgrade later to a larger saw.
-- Steve
View Surfside's profile
Surfside
3389 posts in 2078 days
#8 posted 08-08-2014 09:14 PM
Pick it up. It’s definitely a good deal.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#9 posted 08-08-2014 11:00 PM
If it does what you need and you saved money from new – yes. It’s a good deal. Don’t pay attention to what anyone else thinks. They aren’t you in your market.
Eastern
#10 posted 08-08-2014 11:36 PM
Thanks for all the input guys….
I picked up the saw and turned in on – works fine.
Tools in the DC area seem to be more expensive. The deep discounts don’t seem as plentiful – Phil, Batlimore and Richmond all have cheaper prices on everything but it’s not worth the gas to travel.
Thanks again guys.
