Properly attaching top to base
« back to Joinery forum
Forum topic by IHRedRules posted 08-08-2014 02:17 AM 925 views 0 times favorited 5 replies Add to Favorites Watch
View IHRedRules's profile
IHRedRules
113 posts in 1385 days
08-08-2014 02:17 AM
I am building a small bookcase/nightstand. The case is plywood, but the top will be solid 1/4 sawn red oak. I was thinking of using biscuits to attach the top to the sides of the base. I know that is not usually the best option since it doesn’t allow much movement of the wood, but since it is only two 6” boards joined together and 1/4 sawn, perhaps I could get way with using biscuits.
5 replies so far
View TheFridge's profile
TheFridge
8908 posts in 1395 days
#1 posted 08-08-2014 02:28 AM
I’ve glued 2”x2”x3/4” thick block in each corner flush with the top of the frame. Drilled a 1/4”-5/16” in center of each block and used screws with washers to allow for movement. Biscuits may work. Probably work, but why chance it?
View firefighterontheside's profile (online now)
17582 posts in 1766 days
#2 posted 08-08-2014 02:35 AM
You could do the biscuit thing in the center and fridges method in the corners. That way the top would stay centered and still allow for movement.
IHRedRules
#3 posted 08-08-2014 10:47 AM
Thanks for the input. I think I will biscuit the center and use glue blocks/screws for the corners
#4 posted 08-08-2014 12:49 PM
Sounds good, just remember the oversized holes and a washer. Enjoy your build.
View bigblockyeti's profile (online now)
bigblockyeti
4994 posts in 1630 days
#5 posted 08-08-2014 01:26 PM
If you’re tight on space, you can also use figure eight washers that allow slight movement: http://www.woodworkingshop.com/product/sl20001/?inMed=GSTORE&gclid=CJb06pvig8ACFQxp7AodIUIAEg
