Goodell Pratt drill dilemma...
« back to Hand Tools forum
Forum topic by apertedevue posted 08-07-2014 02:23 AM 1207 views 0 times favorited 4 replies Add to Favorites Watch
View apertedevue's profile
apertedevue
3 posts in 1459 days
08-07-2014 02:23 AM
I am attaching a photo of this drill I intend to dismantle and clean. I am baffled by the handle: there are 2 symmetrical pins on the shaft of the handle, visible hopefully in the photo, which I assume ought to be pulled out in order to detach the wheel. The pins seem to be almost flush to the surface though. Before messing around with it I thought of asking for expert advice on this forum. Thank you in advance.
View Loren's profile
10377 posts in 3642 days
#1 posted 08-07-2014 02:26 AM
Sometimes, often actually, things are put in with tapered
pins. The taper can be subtle, so measure the end
and using a drift, pound out the pin from the smaller
end.
I use a set of pin punches I got at harbor freight.
apertedevue
#2 posted 08-07-2014 02:52 AM
Thank you for pointing me in the right direction Loren.
Never used pin punches before, and in addition, the ends of the pin are really battered and distorted, so I expect a few hours of punching and guessing. Maybe some liquid wrench overnight would help?
Your site is impressive and instructive, by the way, i will look closely and learn more in the days ahead.
#3 posted 08-07-2014 03:07 AM
You may want to do something like cut the end off
an old round-shaft screwdriver or some odd old
thing to make a drift. I use my punches but
I got by for years with ground off nail sets and
things like that.
yeah, Liquid Wrench is good. I usually try to whack
it dry first. Once a pin moves a little it will pop
out easily if it’s a tapered pin.
apertedevue
#4 posted 08-07-2014 03:27 AM
Point taken.
Thank you again.
