Any ideas on what is holding the inlay in place?
Forum topic by Sandman1022 posted 08-06-2014 06:58 PM 1853 views 0 times favorited 24 replies Add to Favorites Watch
View Sandman1022's profile
Sandman1022
11 posts in 1588 days
08-06-2014 06:58 PM
Topic tags/keywords: rustic
I’m still a beginner woodworker and I saw this in a shop a few weeks back and wondered if anyone had any idea what is being used as “grout” to hold the inlay in place. I’ve seen this done before, but the branch crosscuts were just all wedged together. I was thinking about doing something like this on a future project and I would really like to fill the gaps between the inlay pieces. Any ideas?? I really appreciate your input.
-- How much wood would a wood chuck chuck, oh nevermind......
24 replies so far
View Wally331's profile
Wally331
350 posts in 2224 days
#1 posted 08-06-2014 07:08 PM
Dyed epoxy almost for sure, but considering I’m not an expert that’s about all I can tell you.
View Earlextech's profile
Earlextech
1162 posts in 2889 days
#2 posted 08-06-2014 07:13 PM
It looks to me as if the branch cutoffs were first inlaid into a piece of veneer and then the full sheet inlaid into the top veneer. Time consuming, yes, but that what you get with veneer.
View Yonak's profile
Yonak
986 posts in 1720 days
#3 posted 08-06-2014 10:50 PM
It could be tinted Bondo.
- Earlextech
Earl, do you mean the veneer is pressed into the voids between the branches then removed from atop the branches by surfacing ?
View mudflap4869's profile
mudflap4869
1873 posts in 1658 days
#4 posted 08-06-2014 11:09 PM
Glue up the branch peices. Scripe the top to match then cut with a scroll saw. Glue it to a backing then fill with dyed epoxy.
-- Still trying to master kindling making
View Jim Finn's profile
Jim Finn
2686 posts in 3121 days
#5 posted 08-07-2014 01:28 AM
The photo looks to me like a mixture of glue and sanding dust was used as “grout”
-- No PHD just a DD214 Website> craftingcouple.com
Earlextech
#6 posted 08-07-2014 02:30 PM
Yonak, not exactly. Any veneered design is created by edge gluing the veneer shapes together first and then applied as a sheet to the substrate. If these branches were cut to the thickness of veneer, corresponding holes cut into the sheet of veneer and then edge glued into it. You could accomplish this pattern.
Notice my box top, each individual piece is edge glued together then applied as a single sheet onto the box top.
View bigblockyeti's profile
bigblockyeti
5285 posts in 1920 days
#7 posted 08-07-2014 02:37 PM
Dyed epoxy would be my guess too, this could be tricky if too much is used as epoxy doesn’t sand as well as wood and could melt under less than ideal conditions.
Yonak
#8 posted 08-07-2014 03:27 PM
- Earlextech
Do you mean each branch end could have been hand cut out of the veneer ?
Check out this “inlay” job. I’m quite sure he didn’t cut out all the pieces individually :
Earlextech
#9 posted 08-07-2014 03:42 PM
Yes. Most could have been cut using a punch. Also, in looking at the piece again, I’m not convinced it’s actually real wood, which makes this all moot. It could be a fabricated sheet, more of a photographic process than woodworking! After all, we don’t know if this is a custom piece or a factory run.
Yonak
#10 posted 08-07-2014 04:03 PM
Yes. Most could have been cut using a punch. Also, in looking at the piece again, I m not convinced it s actually real wood, which makes this all moot. It could be a fabricated sheet, more of a photographic process than woodworking! After all, we don t know if this is a custom piece or a factory run.
- Earlextech
Sam, you’ve got a good point there about it possibly not being real wood.
Earlextech
#11 posted 08-07-2014 04:08 PM
Yonak, That last post was most certainly cut on a cnc. My wife was a picture framer and she had a cnc to cut fancy mats out, could have done that easily.
Sandman1022
#12 posted 08-07-2014 06:11 PM
This was part of a two piece set in a custom art shop. The two pieces that were done this way were definitely real wood. The grout that was in the joints had kind of a gritty texture look to it. Is it possible that it was sawdust and glue or would that have shrunk too much? Here’s the other piece.
Sandman1022
#13 posted 08-07-2014 06:12 PM
I should have taken a close up shot of the filler. Kicking myself now.
Yonak
#14 posted 08-07-2014 06:37 PM
- Earlextech
Sam, actually it was done with a press and sandpaper. I didn’t do it but I’m referring to the procedure description.
This is a dash plate from a 1927 Cadillac that was refurbished. It’s pretty certain the original procedure was pretty much the same.
Earlextech
#15 posted 08-07-2014 07:33 PM
Yonak, Considering it from ‘27 I’m sure it was a press, essentially a large punch that can be used repeatedly. Some very fine metal smith did make the original by hand.
Sandman1022, Take a look here – http://www.roberts-plywood.com/butt-cut-veneers.html
