newbie with box joints
« back to Joinery forum
Forum topic by startingfromscratch posted 08-06-2014 04:00 PM 1166 views 0 times favorited 8 replies Add to Favorites Watch
View startingfromscratch's profile
startingfromscratch
69 posts in 3155 days
08-06-2014 04:00 PM
I’m looking to start making some small boxes with box joints.
Is there a consensus on whether most people use table saw and jig or router and jig? Easiest to get started on?
Thanks
8 replies so far
View Gene Howe's profile
Gene Howe
10348 posts in 3392 days
#1 posted 08-06-2014 04:03 PM
I’ve used both. I find the TS is easiest to set up and use.
View ChefHDAN's profile
ChefHDAN
1057 posts in 2813 days
#2 posted 08-06-2014 04:04 PM
TS & use a sac board to reduce the tearout
View bigblockyeti's profile
bigblockyeti
5090 posts in 1684 days
#3 posted 08-06-2014 04:06 PM
TS jig is the fastest by far, probably easier to get started on too. If you’re building multiple jigs for different sized joints, mark your jig with which chipper and shims you’re using from your dado stack so future setups will be less take less time.
View Rugman01's profile
Rugman01
13 posts in 1401 days
#4 posted 08-06-2014 04:41 PM
I have the incra box joint jig and it works great on either.
-- The meek shall inherit the earth, when the bold are done with it.
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2033 days
#5 posted 08-06-2014 04:46 PM
I use an Incra on a router table. I have a nicer one now but I started with the 100 dollar plastic jig and love it. The other options mentioned will do box joints faster and easier, but the incra opens up several types of dovetails. including cornerpost.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View intjonmiller's profile
intjonmiller
20 posts in 1785 days
#6 posted 08-21-2014 01:29 PM
Doing them on the router can be nearly as fast as using a dado stack in a table saw IF you have a router lift that is adjustable from the top of the table. As you are startingfromscratch that seems unlikely. The ability to just turn a wheel to move the blade up & down makes it much easier. I started on the router because a straight router bit is MUCH cheaper than a dado stack.
View knotheadswoodshed's profile
knotheadswoodshed
217 posts in 2136 days
#7 posted 08-21-2014 01:38 PM
- Rugman01
I use this also but on TS only, I paired it with a 1/4” flat bottom blade from Infinity and it works great.
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
View timbertailor's profile
timbertailor
1594 posts in 1387 days
#8 posted 08-21-2014 03:51 PM
Also depends on what size projects you are working on.
If you are making small boxes, for example, Infinity has a box joint cutter that will do 1”+ blade pass in one go if you have a router. With some good router travel, you could do much larger joints with an additional adjustment\pass.
I use an Incra Ultra Jig on a router table.
