Green Nylon Scouring Pad
Forum topic by robscastle posted 08-06-2014 09:14 AM 1452 views 0 times favorited 9 replies Add to Favorites Watch
View robscastle's profile
robscastle
5632 posts in 2443 days
08-06-2014 09:14 AM
I was working on my New Guinea Rosewood boxes today and needed to remove some “fur” from a routed Vee profile, I was going to use steel wool as my first choice but was concerned about metalic residue.
As I rummaged about under the sink my wifes green nylon scouring pads caught my eye and I decided to “liberate” a couple out from under the dungeon of the kitchen sink.
They worked a treat I will buy some next shopping run, plus replace the ones I “borrowed”
Any body else used or tried them ?
-- Regards Rob
9 replies so far
View Monte Pittman's profile
Monte Pittman
30148 posts in 2576 days
#1 posted 08-06-2014 09:45 AM
I have never tried them, but we have various grades of them sold here. It could be worth a try.
View Bill White's profile
Bill White
5149 posts in 4199 days
#2 posted 08-06-2014 02:36 PM
I use ‘em (several grades) a bunch. They last a long time, and can be washed and reused.
Bill
-- bill@magraphics.us
View Paul Maurer's profile
Paul Maurer
162 posts in 1793 days
#3 posted 08-06-2014 02:37 PM
I use them for stripping and to rub out a poly finish before waxing.
View Woodbum's profile
Woodbum
846 posts in 3304 days
#4 posted 08-06-2014 07:08 PM
I’ve never used the burgundy or the green scotch brite pads (too coarse) on wood, but I have a couple of packages of the white and grey that I use for rubbing out finishes (lightly). I have used the green and the burgundy on metal tool tops, saw blades and other metallic surfaces when cleaning up rust and corrosion. They work great for that. They come in several “grits”
-- "Now I'm just another old guy wearing funny clothes"
View Finisherman's profile
Finisherman
227 posts in 2088 days
#5 posted 08-07-2014 12:38 AM
I use the green pads all the time for stripping furniture.
View realcowtown_eric's profile
realcowtown_eric
617 posts in 2175 days
#6 posted 08-07-2014 01:39 AM
Trubble is with green scouring pads, they leave little bits of green…same with purple or grey albiet they have different degrees of abrasiveness.
Local flooring tool supply firrms carry white abrasive pads.
-- Real_cowtown_eric
robscastle
#7 posted 08-07-2014 02:15 AM
Well well, so much for discovering something “new”
Here is a shot of some in action
The before shot
and the after shot
I have to agree they tend to leave reside and catch in egde grain if you are not careful.
I will have to explore further the various grades available.
Thanks everyboby for all the feed back and the lack of questioning as to which rock had I been hiding under !!
-- Regards Rob
View JAAune's profile
JAAune
1854 posts in 2555 days
#8 posted 08-07-2014 02:46 AM
Yes, we use enough to buy them in boxes of 10-25. They’re a lot cheaper that way then getting them from the local stores. Custom Service Hardware has good prices on their generic line of pads.
Today we went through about 15 pads stripping down 8 commercial doors and a dining table. That would have been more if we still used paste strippers instead of liquid. They’re actually used during the solvent wash following stripping and not the actual stripping work.
View patrad's profile
patrad
51 posts in 2550 days
#9 posted 08-07-2014 05:13 AM
Have you tried sanding nets/mesh? They leave less. http://www.pennstateind.com/store/PKMESHKIT.html?prodpage=1PK
