Grizzly D3968 riser kit on HF bandsaw
Forum topic by Scott C. posted 08-06-2014 03:09 AM 1143 views 0 times favorited 1 reply Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 1982 days
08-06-2014 03:09 AM
Does anyone know if the Grizzly D3968 bandsaw riser kit is compatible with the Harbor Freight 32208 bandsaw? The grizzly kit is made for the Stellex ST1000 saw, which looks pretty much the same as all the other 14” saws, but I’ve heard the blade guide posts can different diameters. Anyone used this kit?
-- measure twice, cut once, swear and start over.
1 reply so far
View mantwi's profile
312 posts in 1828 days
#1 posted 08-06-2014 03:41 AM
Harbor Freight sells a 6” riser kit for their 14” band saw. It is part # 1C on page 32 of the manual and is available as an accessory. I have seen post by guys who modify the kit to fit other brands to save money so it’s got to be cheaper than a Grizzly riser block and won’t require any modifications. If I’m not mistaken the alignment pins are on the opposite corners of the block and have to be changed if you use a different brand. I’m sure a search will lead you to the part without much hassle.
