Table saw question
Forum topic by Firemanwill posted 08-05-2014 10:48 PM 1679 views 0 times favorited 19 replies Add to Favorites Watch
View Firemanwill's profile
Firemanwill
16 posts in 1434 days
08-05-2014 10:48 PM
I don’t believe in stupid questions. I believe they are all the right questions, but some are asked at the wrong time.
I say this because what I’m about to ask may sound stupid to some of you.
Is it feasible to install a 10” masonry blade on a table saw? I have a ton of slate chalkboard pieces that I need to cut down, but don’t have the cash to shell out for a tile/masonry saw.
I only ask here because I have had good responses from members here and people on other sites think I’m an idiot for asking.
-- The World is Your Oyster.....Grab the Hot Sauce!
19 replies so far
View paxorion's profile
paxorion
1107 posts in 2014 days
#1 posted 08-05-2014 11:08 PM
I would imagine that heat buildup would be the biggest concern.
-- paxorion
View bold1's profile
bold1
293 posts in 1816 days
#2 posted 08-05-2014 11:19 PM
If arbor size and speed are right for the blade you can. Make sure the blade is rated for dry rather than wet use. AND MOST IMPORTANT use a good respirator, not just a dust mask. The dust is hard on the saw itself of course, if it gets into bearings or motor you may be shelling out for a new saw. But can it be done, yes.
View ColonelTravis's profile
ColonelTravis
1756 posts in 1862 days
#3 posted 08-05-2014 11:48 PM
There are no stupid questions, only stupid answers and this may or may not be a stupid answer but I would be terrified to use my TS to cut a ton of slate. Do you have a circular saw? I’d try that. I used my fake Dremel to cut metal, don’t think it would be good for slate but do you have an angle grinder? If those gave lousy results I’d rent a saw built for that job.
10278 posts in 3616 days
#4 posted 08-06-2014 12:04 AM
Stone countertop guys use skill sidewinder saws with water
feeds. The water keeps the cut cool and collects the
dust.
I think you’re gonna wreck your table saw.
You can rent a tile/brick saw at Home Depot, etc.
View bondogaposis's profile
bondogaposis
4688 posts in 2320 days
#5 posted 08-06-2014 12:23 AM
If you value your table saw then I wouldn’t do it. If you are indifferent about the saw, then go for it.
-- Bondo Gaposis
View Woodknack's profile
Woodknack
11486 posts in 2349 days
#6 posted 08-06-2014 05:20 AM
Not very good for the saw. You might get away with it for awhile but it would be smarter to just rent one.
View knotscott's profile
knotscott
7983 posts in 3344 days
#7 posted 08-06-2014 11:27 AM
I’ve put a masonry blade on my circular saw, but wouldn’t do it to my TS….it’d scratch the heck out of the cast iron top.
View Dutchy's profile
Dutchy
2850 posts in 2137 days
#8 posted 08-06-2014 12:02 PM
Hello Firemanwill,
Next picture is from a circular saw:
And this one is from a tile saw:
The only different is that the tile saw is water cooled.
Buy a blade for dry cut when you don,t have water cooling
But I maybe have a stupid question. Why don,t you use a normal circularsaw blade. In other words from what for material are the chalkboards made?
-- https://dutchypatterns.com/
View Redoak49's profile
Redoak49
3201 posts in 1957 days
#9 posted 08-06-2014 12:17 PM
I would not do it as it will probably ruin the saw with the grit getting into everything.
Can you do it with a circular saw? You could probably find a cheap used one and set up a jig to cut the pieces.
Also, there are a lot of places that rent them.
View AnonymousRequest's profile
AnonymousRequest
861 posts in 1517 days
#10 posted 08-06-2014 12:59 PM
Circular saw and a straightedge.
4954 posts in 2462 days
#11 posted 08-06-2014 01:16 PM
I’m in the “it will ruin your saw” camp. What about renting a tile saw?
View lndfilwiz's profile
lndfilwiz
103 posts in 1569 days
#12 posted 08-06-2014 01:39 PM
http://www.harborfreight.com/power-tools/tile-saws.html
One of these may help you. I would not use my TS!
-- Smile, it makes people wander what you are up to.
Firemanwill
#13 posted 08-06-2014 02:42 PM
Thanks everybody. I am now abandoning the idea. I can rent one from the Home Depot. So ill go that route.
View bigblockyeti's profile
bigblockyeti
5101 posts in 1689 days
#14 posted 08-06-2014 04:15 PM
Probably a good plan, I’d only try it on a saw that was already garbage and only do it outdoors where the dust would be less of a problem (still wearing a respirator).
View Grandpa's profile
Grandpa
3259 posts in 2644 days
#15 posted 08-06-2014 08:58 PM
I went on a volunteer job once where they had a table saw set up with a diamond blade on it. We cut Hardie Plank on it. It was working when I got there and working when I left. All I know about how long it continued to work. The dust is hard on things but yes it can be done.
