Outside dust collection and pipe length
Forum topic by Tom posted 08-05-2014 10:16 PM 853 views 0 times favorited 2 replies Add to Favorites Watch
View Tom's profile
Tom
185 posts in 1685 days
08-05-2014 10:16 PM
Hi,
I have been working on getting my shop (garage) organized and cleaned up. I currently have some 2” PVC and a dust deputy off a 6.5HP Shopvac – it works ok but not great so I am looking into upgrade options before winter here in WI sets in.
I am thinking of getting the Harbor Freight 2HP model as I have seen many good reviews of it (when modified) and a Super Dust Deputy to go with it.
I don’t really want to take up that much space in my already cramped space so I am wondering if anyone here has put their dust collector outside – I was thinking of building a simple 2×4 + OSB or Plywood box to go around it and set it on paver bricks – just curious if others had dome something similar and did their dust turn into concrete from moisture? Also I am wondering about how much pipe can be run off a model like that – From where the unit would have to sit outside to the furthest point would be about 20-25 ft and I would need a couple t’s off of that with about 8 foot runs each – would that be to much pipe for a collector like that?
The main dust makers I use are a 6.5” jointer, tablesaw and a 13” planer – the shopvac does about as good as I think can be done on the miter, RAS and a couple sanders..
So anyone else have a similar situation or setup to what I am thinking of doing that can offer some advice?
Thanks,
Tom
-- --Tom - Saint Francis, WI
2 replies so far
View bondogaposis's profile
bondogaposis
4682 posts in 2316 days
#1 posted 08-06-2014 12:14 AM
The problem w/ that set up is that you will be sucking expensive heated air out of the shop into the cold Wisconsin wild. A possible solution, would be to build an insulated shed for the dust collector and then return the filtered air back into the shop.
-- Bondo Gaposis
View Tom's profile
Tom
#2 posted 08-06-2014 12:41 AM
Thanks Bondo,
I am not really concerned about loosing heat via sucking it out into the system – it won’t be on for extended periods, I mainly build smaller hobby projects so it’s a couple cuts here and there, a couple boards through the planer or jointer – so time wise it won’t be on long but those machines make massive messes and I spend far more time cleaning up then I want to, really don’t want to sink $500 or $600 more into it but if it cuts cleanup which I think it will over time it will be well worth it (I hope).
