V-groove router bit
Forum topic by nate22 posted 08-05-2014 09:45 AM 1217 views 0 times favorited 6 replies Add to Favorites Watch
View nate22's profile
nate22
475 posts in 3078 days
08-05-2014 09:45 AM
I’ve been looking at router bits for sign making is the v-groove bit the one I want or is there another one I should use. I just don’t want to waste money on a bit that I don’t need at the moment.
-- Gracie's wooden signs. Middlebury, In.
View BGW's profile
BGW
165 posts in 2210 days
#1 posted 08-05-2014 10:09 AM
A VGroove bit is good for most engravings (particularly words). My other favorite bit is a 1/8” bull nose bit for carvings.
-- Bob, Indiana, "Well done is better than well said." -Ben Franklin http://www.bgwconstructionllc.com/
View rrww's profile
rrww
263 posts in 2316 days
#2 posted 08-05-2014 11:27 AM
You can get v-grooves in different angles 90, 60, 20 degree angles. This gives you a wider range of detail and letter sizes.
+1 BGW on the bull nose bit
View helluvawreck's profile
helluvawreck
32087 posts in 3070 days
#3 posted 08-05-2014 02:13 PM
A lot of people use them for lettering.
helluvawreck aka Charles
View Gentile's profile
Gentile
314 posts in 2021 days
#4 posted 08-05-2014 04:13 PM
Off topic…
I have an old Craftsman V-groove bit that I use in my drill for countersinking screws. It works better for that than in my router.
-- "I cut it twice and it's still too short"
View MrUnix's profile
MrUnix
7051 posts in 2402 days
#5 posted 08-05-2014 05:20 PM
Unless your needs are very limited, you will want more than just one bit. A V-groove bit is suitable for lettering as Charles stated.. but you are limited to the thickness of your bit if you go that style. I do lots of raised lettering and other raised ‘artwork’ type signs, and find that using either flat or bull nose (rounded) bits worrk better for that purpose.. it’s hard to hog out large areas with a V-bit! You also will probably want to do some kind of edging on the signs.. various sized round over/chamfer bits can be used to make rounded and scalloped edges. Fancier edging can be done with cove, ogee or other bits in combination or separately. Would probably be best to purchase a basic set and see which ones you wind up using the most for the type of work you want to do; then invest in some better quality ones once you know.
View Jim Jakosh's profile
Jim Jakosh
21740 posts in 3308 days
#6 posted 08-05-2014 08:50 PM
I use 90 degree,and 60 degree V- groove bits and 1/8, 3/16 and 1/4 ball nose bits for signs.
