End grain countertop over dishwasher
Forum topic by yellowtruck75 posted 08-05-2014 01:10 AM 1029 views 0 times favorited 5 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3064 days
08-05-2014 01:10 AM
I have a customer that wants a 24” square end grain counter top over their dishwasher. Should I be concerned about excess moisture.?
5 replies so far
View KayBee's profile
KayBee
1083 posts in 3244 days
#1 posted 08-05-2014 01:37 AM
Most dishwashers have a vent right near the counter top. This is for excess moisture. During the dry cycles, it’s basically steam. I don’t know how long or how well an end grain counter top will hold up to that.
-- Karen - a little bit of stupid goes a long way
View rrww's profile
rrww
263 posts in 2110 days
#2 posted 08-05-2014 11:24 AM
Have her sign a release if you do it. I have seen some dishwashers create a ton of steam. I wouldn’t do it.
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2068 days
#3 posted 08-05-2014 12:19 PM
I did mine….in a face grain. I also made sure that first piece that ran parallel to the door was wider then the door, so any steam would hit wood rather then a glue line. I was worried but had no choice as we needed a top and had run out of budget but of course I always have lots of lumber. It has worked out fine although my dishwasher dosnt put out a ton of steam. I also ran clear silicone under that lip, anything to keep the moisture and heat away. I would not try this with an end grain and would be nervous to do it again. Id make sure my customer knew that it could all go very bad…
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#4 posted 08-05-2014 12:37 PM
Laminate a piece of sheetmetal to the bottom of it.
View tinnman65's profile
tinnman65
1357 posts in 3411 days
#5 posted 08-05-2014 08:57 PM
In all honesty I have never built a end grain cutting board but it seems to me it would be more about glue failure with the moister and heat. I would think the right choice of glue would solve any potential future problems. It sure wouldn’t hurt to keep something under it as dhazelton suggested. Let us know how it goes.
-- Paul--- Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. — Scott Adams
