Help with chair leg taper on table saw
Forum topic by Boomerriz posted 08-04-2014 07:11 PM 1037 views 0 times favorited 4 replies Add to Favorites Watch
View Boomerriz's profile
Boomerriz
5 posts in 1418 days
08-04-2014 07:11 PM
First post here, relatively new to the field.
I’m trying to make a set of kitchen chairs, but the back legs are giving me fits. They’re 1 piece of wood that tapers back starting at the seat. Here’s an image I found that’s similar:
I built a tapering jig and I can cut the open side of the angle no problem, but I’m having issues trying to figure out the best way to cut the inside taper on a table saw because the reach of the blade will gouge the bottom half an inch or so.
Any advice? Best I can come up with is to stop each cut about an inch short and finish the rest out by hand, but I’m afraid it will not look good.
Any help would be much appreciated!
View CharlesA's profile
CharlesA
3329 posts in 1824 days
#1 posted 08-04-2014 07:15 PM
The simple answer is a bandsaw.
View Bill1974's profile
Bill1974
125 posts in 3012 days
#2 posted 08-04-2014 07:15 PM
template and a patterning bit in a router table
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2136 days
#3 posted 08-04-2014 07:19 PM
Both of the above…
I’d make a 1/4” MDF template, carpet tape it to the stock, band saw close to the pattern, then finish with a pattern bit and router, repeat as necessary…
Boomerriz
#4 posted 08-04-2014 07:36 PM
Thanks so much for the quick answers! I hadn’t thought about a patterning bit but I think that makes a lot of sense.
