Proper time to use a butterfly key?
« back to Joinery forum
Forum topic by RyRat posted 08-04-2014 03:19 PM 1103 views 0 times favorited 3 replies Add to Favorites Watch
View RyRat's profile
RyRat
27 posts in 1386 days
08-04-2014 03:19 PM
Topic tags/keywords: butterfly key checking
I am working on a few live edge coffee tables and was wondering when is the proper time to use a butterfly key? I have some minor checking, see photo, and some splits straight through. None of them are more than 1/16 of an inch wide. I sometimes see work with half a dozen butterfly keys within a foot of each other. This looks like too much to me. How little can I get away with?
-- If you are flammable and have legs, you are never blocking a fire exit. -Mitch Hedberg
3 replies so far
View jmartel's profile (online now)
jmartel
7624 posts in 2020 days
#1 posted 08-04-2014 03:38 PM
For those in the photo I’d probably just fill them with epoxy. For ones going straight through, use butterflys.
View giser3546's profile
giser3546
179 posts in 1343 days
#2 posted 08-19-2014 06:31 PM
I don’t think the issue in the picture would require butterfly keys, unless the wood is still fairly green and you’re expecting significant movement. Especially with how close that is to the edge, I know I would probably cause issues trying to put in a butterfly there. Some of the overzealous butterfly keys I’ve seen were made of veneer and weren’t even functional so those that you’ve seen may have just been for look.
-- "If you wait for it to rain, It will"
View pintodeluxe's profile
pintodeluxe
5544 posts in 2683 days
#3 posted 08-19-2014 06:43 PM
You can use them as decoration, or to stabilize minor cracks. For deeper splits, the inlay should be fairly thick.
