What to do about my Tormek grinder
Forum topic by newwoodbutcher posted 08-02-2014 11:29 PM 980 views 0 times favorited 3 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
780 posts in 3084 days
08-02-2014 11:29 PM
After 22 years of moderate use my Tormek sharpener is acting up. If I apply anything more than light pressure while grinding the motor bogs down. I’m not very mechanically inclined so I’m thinking if it’s not something simple (like brushes) I’ll be needing a replacement. I don’t even know if the motor has brushes. Has anyone already solved this problem?
-- Ken
3 replies so far
View madts's profile
madts
1884 posts in 2574 days
#1 posted 08-03-2014 12:11 AM
I would give it a good cleaning. Take the grind stone off, then slide the wheel with the leather belt off. Inside you will find a shaft sticking out. That can get dirty and cause you some problems. Clean it all up and you might be good to go.
-- Thor and Odin are still the greatest of Gods.
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#2 posted 08-03-2014 12:16 AM
+1 for madts
Here’s the USA Tormek agent for added help if needed:
Retail Outlets
Online Retailers
Online Repair Parts
USA Agent
Affinity Tool Works
1161 Rankin
Troy, MI 48083
Tel: (800) 586-7635 Toll-Free
Tel: (248) 588-0395
Fax: (248) 588-0623
info@affinitytool.com
http://www.affinitytool.com
http://www.sharptoolsusa.com/
HTH
newwoodbutcher
#3 posted 08-03-2014 12:55 AM
Great help. Thank you. I’ll check it out tomorrow.
-- Ken
