Ridgid 13002 vs Dewalt 733
Forum topic by trevorlamont posted 08-01-2014 02:36 PM 967 views 0 times favorited 3 replies Add to Favorites Watch
View trevorlamont's profile
trevorlamont
15 posts in 1866 days
08-01-2014 02:36 PM
I am looking at 2 very lightly used planers Ridgid 13002 and the Dewalt 733. Both come with stands. The Ridgid is being sold for $200 and I talked the Dewalt down to $250. I like the Repeat a cut feature on the Ridgid. I’m torn cause I feel like the Dewalt would be a better planer possibly.
Please advise. I’m still a beginner at woodworking.
Thanks,
Trevor
3 replies so far
View CharlesA's profile
CharlesA
3305 posts in 1701 days
#1 posted 08-01-2014 02:43 PM
Trevor, I have the Ridgid ZRR4330 planer (one model older), and I am very happy with it. Does everything that I ask of it (other than planing wood 16” wide).
That being said, a comment on the repeat a cut feature. I used it a lot at first, and it is great if you’re doing a project with all 3/4” wood, so any variation fro 3/4” will be uniform across the project. I’ve been doing more work with multiple thicknesses with a need for very tight joints, and I’ve found myself relying more on calipers and less on the repeat a cut. It depends on what you’re using it for, how tight you want your tolerances, and how much you like cleaning up joints.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2753 days
#2 posted 08-01-2014 04:55 PM
I sold my TP 1300 (Grey version) on CL and bought the DW735. I’ve only ever looked at the DW733 in the stores, and an actual owner of a DW733 can pro or con it for you but as for the TP1300, I did not like the duct collection and the cutterhead lock always seemed to come loose when running a lot of BF through, not a bad unit overall just annoying, if you look at the TP1300 look under the wings and see if the additional set of blades is there.
View pintodeluxe's profile
pintodeluxe
5565 posts in 2717 days
#3 posted 08-01-2014 04:58 PM
The Dewalt 735 has several depth stops that are reliable and repeatable. It is such a handy feature, I would not buy a planer without good depth stops.
