Splotchyness finishing red oak
Forum topic by ShawnSpencer posted 08-01-2014 12:24 PM 873 views 0 times favorited 1 reply Add to Favorites Watch
View ShawnSpencer's profile
ShawnSpencer
81 posts in 1417 days
08-01-2014 12:24 PM
Topic tags/keywords: question oak finishing
I am finishing my plant stand project and having trouble with the stain being splotchy. On red oak, I applied a 2lb cut of amber shellac. Lightly sanded with 400 grit. Then, applied 2 coats of GF walnut gel stain. I chose the shellac under coat and gel stain specificly to aviod the splotch. Any advice out there?
-- I know you know...
1 reply so far
View rrww's profile
rrww
263 posts in 1988 days
#1 posted 08-01-2014 12:51 PM
I’m thinking that the 2lb cut of shellac is the problem. If it wasn’t applied & sanded evenly it is blocking even stain penetration. On red oak you shouldn’t have to deal with hardly any blotching I would have skipped the shellac.
It it was me I would sand and start over for the best results, depending on how bad it is. If your spraying you could try using a toner coat.
