cyclone dust collector issue
Forum topic by knotheadswoodshed posted 07-31-2014 04:14 PM 1312 views 0 times favorited 11 replies Add to Favorites Watch
View knotheadswoodshed's profile
knotheadswoodshed
219 posts in 2167 days
07-31-2014 04:14 PM
Hi all,
I have a Laguna cyclone dust collector that currently seems to be filling up the bag on the filter canister faster than the barrel.
any ideas as to why this is happening?
I am running 2 – 10’ hoses off the original Y that came with the collector, one is connected to my saw, the other gets moved between the BS, jointer and Dewalt planer. It almost seems like the planer is blowing it right past the cyclone section and into the filter bag.
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
11 replies so far
View English's profile
English
655 posts in 1471 days
#1 posted 07-31-2014 04:33 PM
Check for leaks between the cyclone and the barrel. If you get a bad seal in this area will cause the DC to bypass the barrel and send the dust to the filter.
-- John, Suffolk Virgina
knotheadswoodshed
#2 posted 07-31-2014 07:04 PM
that was my thought as well, but it seems to be sealed
Shawn Masterson
1325 posts in 1943 days
#3 posted 07-31-2014 11:48 PM
spot on English
knotheadswoodshed
#4 posted 08-01-2014 11:43 AM
any other thoughts?
View ohtimberwolf's profile
ohtimberwolf
799 posts in 2346 days
#5 posted 08-01-2014 12:36 PM
This guy had a problem and here is his solution. It might help yours if you don’t find another.
http://jrwagner.org/blog/2013/08/31/laguna-0516-dust-collector-improvement/
-- Just a barn cat, now gone to cat heaven.
View Blackbear's profile
Blackbear
137 posts in 2213 days
#6 posted 08-01-2014 12:39 PM
If you are using the Dewalt 735 Planer it has it’s own blower fan. It is not really meant to be hooked up to a dust collection system, and if I recall it says as much in the directions. Just a thought, not sure about the other issues.
View gtbuzz's profile
gtbuzz
427 posts in 2436 days
#7 posted 08-01-2014 01:03 PM
The only think that even comes to mind is exactly what English said… sounds like there’s a leak in between the cyclone and the collection barrel. The cyclonic effect doesn’t really work if there’s a pressure differential between the two, so even a small leak can really throw things off (I’ve done several times on mine accidentally).
If I remember correctly, this Laguna has some sort of hose attachment for the bottom of the barrel to keep the collection bag from getting sucked up into the cyclone? Is there potentially a leak there? Are you using the bag? Those are just guesses, but I’m stumped for ideas outside of the seal.
View johnstoneb's profile
johnstoneb
2910 posts in 2167 days
#8 posted 08-01-2014 01:07 PM
I would go with English. The 735 fan only clears the chips from the planer doesn’t affect DC at all. Manual states fan-assisted chip ejection will work in conjunction with independent dust collection systems. Shop vacs are not recommended they don’t have to copacity to keep up with the planers ability to produce chips.
-- Bruce, Boise, ID
View distrbd's profile
distrbd
2252 posts in 2441 days
#9 posted 08-01-2014 01:43 PM
Just to clarify something about 735,according to the manual ,a 735 is not recommended to be connected to most shop vacs but not all,a large Ridgid vacuum connected to a Dust Deputy can handle the 735 chip blower,the only trick is (as it is with full size Dust collectors)to turn the vac/dc on before the planer.
-- Ken from Ontario, Canada
Blackbear
#10 posted 08-01-2014 05:51 PM
I’m not saying its definitely the planer, just offering a troubleshooting option to look at. I have the same planer and it has a jet engine of a chip ejector! A simple test would be to use all of your other tools normally with the DC, but not the planer for a project to see if it cures the issue. Or don’t, its up to you.
knotheadswoodshed
#11 posted 08-02-2014 02:01 PM
thanks to all for your thoughts on this
