sanding sleeve on oscillating spindle sander is stuck
Forum topic by Perel posted 07-30-2014 03:24 AM 2445 views 0 times favorited 3 replies Add to Favorites Watch
View Perel's profile
Perel
2 posts in 1398 days
07-30-2014 03:24 AM
When I began setting up the 2” sleeve on my Powertec oscillating spindle sander I forget to put the appropriate washer on top of the sanding drum. I turned the power on and the drum became jammed on the spindle and now I can’t remove the drum. Help from anyone out there would be greatly appreciate.
3 replies so far
View Jim Jakosh's profile
Jim Jakosh
20489 posts in 3106 days
#1 posted 07-30-2014 03:55 AM
I’m not familiar with that brand, but if it like mine, there is a 1/2” spindle and you slide the rubber drum over it with the corresponding size sandpaper drum. When you tighten the nut on the top it expands the rubber into the paper drum to hold it tight. With mine if I don’t tighten up the nut ans washer on top, the drum will slide up and down freely. I’m trying to picture what is happening to yours if you did not have the washer. it seems that it would be too loose to work. Can you remove the nut on top?
Can you post a picture of it? Use the IMG above here to load in a photo.
Thanks,Jim
View lwellsmo's profile
lwellsmo
1 post in 1332 days
#2 posted 10-03-2014 10:52 PM
Did you ever get your spindle off? I have the same problem. Only 2 in the whole world! I am frustrated.
View Steve Peterson's profile
Steve Peterson
377 posts in 3083 days
#3 posted 10-04-2014 12:16 AM
I hope I am not stating the obvious, but on my Ridgid, the nut has a left handed thread. You have to “tighten” it to loosen the nut. I also cut a 5 sided hole in a piece of wood in the shape of the nut to add some leverage to loosen it. Even with normal operation, it is nearly impossible for me to remove without my special tool.
-- Steve
