Split-Top Roubo question
« back to Hand Tools forum
Forum topic by newwoodbutcher posted 07-29-2014 09:17 PM 1463 views 0 times favorited 5 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
740 posts in 2851 days
07-29-2014 09:17 PM
As far as I can tell the reasons for the split top on the Roubo workbench is for portability and to allow for the slot stop feature. I don’t care about portability or stops. I’m making my bench 5’ long x 24” wide. I’m using the Bench craft leg and wagon vices. Are there any other benefits to splitting the tops that I’m missing?
-- Ken
5 replies so far
View John's profile
John
244 posts in 1582 days
#1 posted 07-29-2014 09:59 PM
I believe a main feature is to add clamping ability. You can also hang a cabinet drawer over the end to work it after its assembled. And the slot stop can be traded out for a tool tray.
I think the split top is just a convenient way to have tools drop to the floor. :)
-- I measured once, cut twice, and its still too short...
View RPhillips's profile
RPhillips
1180 posts in 1837 days
#2 posted 07-29-2014 10:42 PM
agree with John on this one, clamping and allowing you to do things like drawers and such would make this design ideal.
Check out the “Workbench Smackdown” thread if you need any inspiration… plenty there to choose from.
-- Rob - Indianapolis IN - Learning... one mistake at a time...
View BubbaIBA's profile
BubbaIBA
387 posts in 2377 days
#3 posted 07-30-2014 10:36 AM
The prime advantage of a split top is in the build. Two smaller slabs are easier to handle than one large one. Most shops do not have a 25” planer, with a split you can use either a lunchbox or a 20” planer to dimension your slabs. A secondary advantage is small mistakes in size of either the base or the top can easily be hidden in the split. Another is it allows a wider base for a given working slab size.
As for tools ending up on the floor, if you size the tool holder part correctly it will not happen.
You may find the “stop” feature not very useful and while I will occasionally use the split for clamping it isn’t used that often.
My last two benches have a split top, I debated using a single vs, split slab for the last build and went with the split for the reasons stated above.
The new bench is in the foreground with the older bench in the background.
BubbaIBA
#4 posted 07-30-2014 10:52 AM
- newwoodbutcher
Is there a reason for a 5’ bench? If you have enough room a couple or three extra feet will make a huge difference in usability.
newwoodbutcher
#5 posted 07-30-2014 08:52 PM
newwoodbutcher,
Great suggestion. I’ll for sure make it longer to fit the space. Should be 6-8 ft long
-- Ken
