How to Save and Print Porter-Cable Manuals?
Forum topic by NedG posted 07-28-2014 01:50 PM 796 views 0 times favorited 3 replies Add to Favorites Watch
View NedG's profile
56 posts in 2247 days
07-28-2014 01:50 PM
I wish to download and then print a Porter-Cable manual, but it’s difficult or impossible to do so, as I can only find it in an Adobe .pdf format. Is there a way to otherwise save and then print their manuals? Thanks very much. —- Ned
3 replies so far
View jmartel's profile
7741 posts in 2083 days
#1 posted 07-28-2014 02:21 PM
Is there a reason you can’t use Adobe PDF? I believe Adobe reader is free to download from them and you can print and save using it. You just can’t create or edit PDF documents.
View mpounders's profile
871 posts in 2828 days
#2 posted 07-28-2014 02:41 PM
You can save the pdf file to your pc and print it whenever. They use the pdf format so you can’t edit and change their property (the document).
-- Mike P., Arkansas,
View MrUnix's profile
6483 posts in 2132 days
#3 posted 07-28-2014 08:27 PM
Right click → save as…
The PDF format has been an open standard since 2008, so pretty much every computing platform on the planet can handle it without much fuss. You should be able to save and print them just like any other document, and there are a bunch of utilities (mostly open source and free) that let you convert to other formats (such as postscript) easily should you require it..
