I received a collet chuck system.. I also bought some mandrels to use with it. Everything seemed to fit on the lathe great but when I turned it on I get a wobble. I am pretty sure that this isn't common right? What do I check first to get the wobble out?
This is quite a common problem! First check you don't have any little bits of dust or swdust between the register on the chuck and the spindle. This can happen quite frequently on a new fitting,especially around the shoulder.
it must come up to and meet the spindle shoulder very firmly and without interuption I.E any crud no matter how small can cause this believe me.I have had it on new chucks of mine it takes a few minutes to fix.I would emphasize the chuck must sit firmly against the shoulder see terminology on google if not sure.It might be a small manufacturing problem that needs a file or other sharp instrument taken to it. If in any further doubt show us plenty of photo's of the set up you have, at all stages. Also show the spindle and the threading area at the back of the collet chuck it all needs to be super clean assuming it has been cleanly machined and no bits of metal swarf are interfering with the fit.Keep us informed and yes you can contact me privately if you want one on one advice I will be only too happy to help you my friend regards and good luck in the meantime Alistair
Thanks so much for the info scotsman. I was going to take pics but ran out of time. I will keep you posted after trying the few things that you said. If it persists I will definitely take pics/video.
From your photo, it looks to be way off center, but they machine these parts in one set up on a cnc lathe so I would think it would be cut almost perfect. That photo does not look like it was taken perfectly square with the face, because the threads on the left are showing more than on the right. I would mount it in the lathe without a collet in there and put an indicator on the tapered surface that pulls the collet tight to check its concentricity!
Just thinking about how it works, what is behind the collet to seat when you pull it tight with the nut?
Does it go into the Morse taper of the spindle??
...............Jim
I bought the PSI collect chucking system (LCDOWEL), and the sleeve nut has a single eccentric ring/ shoulder machined in it just as your appears to be. I can easily tip any of the collect inserts about 20 degrees and it slips into the nut fully….proper orientation required, naturally. Then the chuck compresses the insert cleanly and if I recall correctly, I measured ~0.002" radial runout with the 1/2" insert.
I am still very new to lathe work, so I called PSI support and all I can remember is coming away more confused due to both my and the support person's lack of knowledge. After a couple uses, it dawned on me that the eccentric ring fits the grooves on the outside of each of the collet inserts to remove the compressed collet insert when unscrewing. As you should be able to make out in the image below, the front face (and therefore the seating surface of the sleeve nut) is concentric, which is what matters.
(Sorry the image is so large, but I think you get the gist.) If you've already got the inserts fully and properly seated against the sleeve nut interior face, with the faces of the insert and nut parallel, then I believe you have a runout issue.
When I say ground into where the top of the collet sits. If you look at justahobby's pic the collet face is down and the angled edge sits where it is ground on the collet. I know the picture is slightly off center but you can see that the two circles don't come close to lining up.
Just for reference, this is the interor of my chuck collar/ nut:
It appears similar to yours, rotated by a few degrees CCW, I think. The green lines are the collet insert mating face (~60deg inclusive angle to front face) and the blue lines are the back plane of that edge. Then there is a ~1mm gap before the beginning of the eccentric collet "shoulder", the back plane of which is denoted by the red lines.
The manual for this chuck states "This product does not assemble like any other compression type fitting. ... The collet will "SNAP" into place when correctly assembled." Mine does not need to snap, but hey, it works:
I got confirmation from the tool company that this is the way they are made. They also gave me instructions on how to mount it which is a little different than what i read up on the forums. The company says to put the collet in the collar then the collar on the chuck and then put the chuck on the lathe. So I will be trying that and will keep you posted.
Alright the saga continues!!! I went back and put it together like the company told me to. I still have the wobble! I proceeded to put on a four jaw chuck with the mandrel and boom runs straight. So I know it isn't the lathe. The only thing I can think of is that the chuck isn't sitting on the head stock completely. In the picture you can see a gap. Is that right? The four jaw chuck site all the way back.
Judging by its size that seems to be an ER32 collet chuck, Hard to tell without seeing it in person…
On ER collets the collets are always put into the collet nut first at an angle then snapped to sit straight then inserted into the main body. that's why inside of the nut is offset, and why there is a groove around the outside dia of the collet. It also helps to pull the collet out of the body is it sticks a bit. To remove the collet from the nut apply side pressure to the collet and it pops out…
But yes the collet body isn't fully seating on to the spindle anyway so something is not quite right.
Edit…I was just thinking of another possibility that the spindle length from the shoulder to the end of the threads may actually be to long for that brand of collet…
Yours looks to be a Beall which is what mine is but is used on my South Bend 9a… I'll check the thread length on mine for you.
I have an idea for you where you won't need that collet set up. I started out with wood collets but now have hard plastic ones with a full range of sizes. But, the wood ones worked very well as long as I used them.
Turn a tenon on a piece of hardwood and then cut the piece to about 1" long. For a 1/2" collet, make the tenon just a little bigger than the minimum your chuck needs to tighten. Then drill or bore an accurate size 1/2" hole into it. Mark the jaw number on the tenon so you put it back in at the same location. Then take the collet out and cut a slot from the outside to the inside hole so it can spring open and closed in the chuck. Then at every 90 degrees cut 3 more slots about halfway in from the outside to give the collet equal movement when tightened. I don't have a photo of mine now but I use them for external grabbing and also internal grabbing for rings and bracelets!..............Jim
I have a PSI chuck as well and have found it to be reasonably true. As others have mentioned your setup doesn't look to be seated properly. Also, the longer the collet chuck assembly the more pronounced your error will be. If you are holding metal mandrels and need something more precise you might try collets that are designed to fit the Morse taper of your headstock. I did a comparison of several collet systems a while ago:
These are all MT2, and run dead true. I subscribe to the theory that simpler is better, and the fewer adapters, collars, locknuts, etc. you have in the mix the better.
These do require a draw bar … I made one out of a piece of threaded rod, and a plastic knob.
So I contacted the machine company and they steered me to some things to check. They said measure the spindle and the chuck. They both measure the same 1 1/2". I have cleaned the spindle with the wire brush everything is clean but the collet chuck will not Seat all the way on. I have looked at the threads and they look clean etc.
My problem is I have a four jaw chuck 1 1/2" and it threads on with ease and seats fine and runs true. Do you think there is a problem with the threads?
Other thing is is there anybody in the capital district NY that has a powermatic 90 that I can see if it screws on to?
Maybe, but since your scroll chuck seats fine I would suspect the collet chuck. If it were mine, I would return it to the vendor and buy individual collets from the Little Machine Shop ( http://www.littlemachineshop.com/products/product_category.php?category=874479994 ). All you need with these is a draw bar (that you can make with threaded rod from the hardware store). They insert into your spindle … no need to 'thread', 'seat', etc.
I went to The Little Machine Shop site and they only have MT2 collet set up to 1/2". Not good, they don't even sell larger ones. I'm wondering if this guy ever solved the problem with the PSI collet set. I hate it when they don't publish the result.
Just saw this, They ended up sending me a new chuck and that one still had a wobble. The problem with the chuck was that it would not seat against the collar of the lathe. I could have made a spacer to remedy the problem but I spent too much on it for it not to work right out of the package. I ended up buying a mt2 collet chuck with a bar that went through the head stock problem solved.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
