Seems like a good buy on a router table plate
Forum topic by cutworm posted 07-28-2014 01:08 AM 852 views 0 times favorited 2 replies Add to Favorites Watch
View cutworm's profile
cutworm
1075 posts in 2664 days
07-28-2014 01:08 AM
Bench Dog 40-125 ProPlate Large Blank – $22.50 on Amazon. Aluminium. $65 at Rockler.
http://www.amazon.com/gp/product/B001IKJKH0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I have one on the way. My phenolic plate is starting to sag a little.
-- Steve - "Never Give Up"
2 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2448 days
#1 posted 07-28-2014 06:46 AM
Not bad, but 6 screws to change the insert? Then to level the inserts, you test, unscrew, shim with tape, screw the insert back in place, test again, etc.
Not a good design, but for the money not a bad deal at all. Keep in mind it’s not designed for most typical router table plate openings, so it’s not a drop in replacement. On the bright side, making a template is easy. Since the corners are 3/8” radius, you can position the plate in place, carpet tape 4 boards around it is, and rout the opening with a 3/4” diameter pattern bit and it’ll be a perfect fit.
cutworm
#2 posted 07-28-2014 12:25 PM
Thinking about drilling and tapping holes for set screws to adjust. Or jack screws under the table. A project for this winter. Thanks for the tip on the template.
