Ok, so what is it?
Forum topic by DonBoston posted 07-26-2014 08:36 PM 2407 views 0 times favorited 15 replies Add to Favorites Watch
View DonBoston's profile
DonBoston
81 posts in 1365 days
07-26-2014 08:36 PM
I had purchased a lot of tools from my neighbor, who is now in the final stages of life and can no longer use his tools. One of the tools I picked up was a large old lathe. Well, he came over today and said that he has something which he thinks went with the lathe.
So I went over there, and this is what he handed me.
I’m pretty darn sure it doesn’t go with the lathe, and that platform looks like some sort of router base.
So… what is it?
-- Don Boston RECreations by Don http://recreationsbydon.com
15 replies so far
View MrRon's profile
MrRon
4627 posts in 3146 days
#1 posted 07-26-2014 08:39 PM
It is a router attachment for routing flutes on legs in the lathe. The lathe doesn’t run when fluting. It only indexes the work.
View Grandpa's profile
Grandpa
3259 posts in 2578 days
#2 posted 07-26-2014 08:40 PM
You are correct but in the Oklahoma heat this afternoon I cannot remember what they are called. You need a lathe to go with it but this holds a router and I believe you copy with it. I can’t remember right now. We will both be enlightened. You so want this though. There you go. Mr. Ron had the answer. See you do want it.
DonBoston
#3 posted 07-26-2014 08:54 PM
hrmm… I guess I should keep it then. Now, where to store this thing and the huge lathe it came with….
Thanks
MrRon
#4 posted 07-26-2014 09:08 PM
Don, You can store it with me.
DonBoston
#5 posted 07-26-2014 10:06 PM
I also discovered, that when you move the sled for the router that the leg it’s holding would spin. For spiral flutes I assume? I can’t find a way to stop it from spinning either.
Oh, and it seems I’m missing part of the lathe, the leg for the non-business end. Whatever that’s called. haha
Any idea where to find the leg for a 113.228160 Craftsman 12” lathe?
View NoThanks's profile
NoThanks
798 posts in 1432 days
#6 posted 07-26-2014 11:01 PM
You are correct but in the Oklahoma heat this afternoon I cannot remember what they are called. You need a lathe to go with it but this holds a router and I believe you copy with it. I can t remember right now. We will both be enlightened. You so want this though. There you go. Mr. Ron had the answer. See you do want it.
- Grandpa
you might be thinking a Legacy Ornamental Mill??
-- Because I'm gone, that's why!
View Beatnik's profile
Beatnik
37 posts in 1304 days
#7 posted 07-27-2014 12:29 AM
I think Sears called those a router crafter, I sorta remember from catalogs. Never seen or used one myself. Heres a video of how they work and I think you use different bits for different results ?
http://www.youtube.com/watch?v=gLmcxIws1R8
http://www.youtube.com/watch?v=OdKL2AEHvr8
View Bundoman's profile
Bundoman
153 posts in 1492 days
#8 posted 07-27-2014 02:14 AM
I believe router crafter is correct. My brother in law passed one on to me awhile back. I have not messed with it much. He used it for customizing spindles on a project he had. As I recall, he did all of his work with just a router. I believe that mine has a crank handle on one end that advances the wood and router at the same time. It took him some setup and practice, but he got some reasonable results with it.
-- Brent
DonBoston
#9 posted 07-27-2014 03:26 AM
- Beatnik
That is exactly what I was given… minus the crank. Sigh….
Thanks for the vids, that’s what I thought it did after looking at it more.
View Larry's profile
Larry
24 posts in 2589 days
#10 posted 07-27-2014 03:39 AM
Bundoman is correct, there is no lathe involved. I had one I bought at a garage sale without a crank also and made my own crank out of scrap iron or a piece of allthread bent, I don’t remember but it wasn’t too difficult. I ended up selling mine on ebay a few years ago, was quite a demand for them if I remember correctly. They are still marketed in the UK under another name.
View Crank50's profile
Crank50
173 posts in 1479 days
#11 posted 07-27-2014 01:37 PM
Yep, I was thinking that was a Router Crafter as well.
It is not a lathe attachment, it is a kind of a lathe itself.
View gdpifer's profile
gdpifer
47 posts in 2583 days
#12 posted 07-27-2014 01:53 PM
Yeah, it is a router crafter. Search on LJ and find my blog on it.
-- Garry, Kentucky
View REO's profile
REO
928 posts in 1977 days
#13 posted 07-27-2014 03:00 PM
it is a router crafter by sears. it is used stand alone no lathe involved. much like a scaled down legacy wood milling system.
View helluvawreck's profile
helluvawreck
30112 posts in 2769 days
#14 posted 07-27-2014 03:05 PM
That will be very nice for your shop. Congratulations.
helluvawreck aka Charles
View RogerM's profile
RogerM
790 posts in 2302 days
#15 posted 07-27-2014 03:19 PM
REO is correct. I had one but it was never very effective at what it was supposed to do. It also was designed to cut spirals and flutes.
-- Roger M, Aiken, SC
