Transfast homestead dye/topcoat compatibility
Forum topic by Russell Eck posted 07-26-2014 09:32 AM 1173 views 0 times favorited 1 reply Add to Favorites Watch
View Russell Eck's profile
Russell Eck
165 posts in 1662 days
07-26-2014 09:32 AM
I am dying wood with the water based transfast dye powder, on their website it says “can be top coated with any finishing material”. Does anyone know if I can use a water based acrylic polyurethane or will that destroy and lift my dye. Do I have to seal with dewaxed shellac first?
1 reply so far
View JAAune's profile
JAAune
1854 posts in 2554 days
#1 posted 07-26-2014 02:35 PM
You’ve got two options. There may be more but I’ve not discovered them yet. You can seal it in with a drying oil or oil-based stain with sealing properties like Minwax or spray on a sealer coat of whatever finish you want to use. Using a brush or rag to apply a topcoat tends to smear the color around. The spray gun doesn’t so long as the first coat isn’t heavy enough to cause runs or drips.
