Howard feed-n-wax or minwax paste wax?
Forum topic by Oliver1650 posted 07-26-2014 04:30 AM 7849 views 0 times favorited 8 replies Add to Favorites Watch
View Oliver1650's profile
17 posts in 1396 days
07-26-2014 04:30 AM
Topic tags/keywords: howard feed-n-wax finishing wax
Hi, I am looking for advice on this product as a finishing touch to my grandfather clock I have been building. The picture shows the color of the clock (red oak w/ rustolem american walnut oil stain and three coats of minwax wipe on satin poly). I picked up this Howard feed-n-wax tonight, I was looking for paste wax for darker wood but did not find any. I also have on hand minwax natural color finishing wax but I had a bad experience with it getting cloudy on a walnut shelf I built a few years ago and I am gun shy to use it on this clock project. My plan is to rub out the finish with either of these products and 0000 steel wool tomorrow, it is a wedding present for my daughter, the wedding is in two weeks and I need to get the finish wrapped so I can install the clock guts and glass before my deadline.
Any opinions on which wax I would be better off with?
-- Dan
8 replies so far
View Don W's profile
Don W
18662 posts in 2501 days
#1 posted 07-26-2014 12:00 PM
I don’t really have advice for your clock, but maybe this will help. I use the Howards feed and wax for older dry wood. I don’t apply it with steel wool, its to thin. Test it to see if it gives the results you want.
my wife would use lemon oil on your clock.
-- - Collecting is an investment in the past, and the future.
View Yonak's profile
986 posts in 1455 days
#2 posted 07-26-2014 01:35 PM
For open grained woods I apply wax with cheesecloth to be certain no steel gets into the wood.
#3 posted 07-26-2014 05:41 PM
Thanks for the ideas, I used both products on a test finished board last night and both seemed ok this morning, the paste wax applied with steel wool was a bit smoother, also i didn’t see any cloudiness so I think i will go with that first and then maybe follow up with the Howard’s, maybe save it for something else.
-- Dan
View lateralus819's profile
2241 posts in 1823 days
#4 posted 07-26-2014 07:03 PM
Howards feed n wax is awesome. It’s the only finish I use now. Enhances the beauty of the wood quite well and it’s easy to apply.
View Redoak49's profile
3133 posts in 1922 days
#5 posted 07-26-2014 10:16 PM
It looks like a great project that you put a lot of time into. I would take your time about which product or if you are going to use either. I would watch the two test samples for up to a week and make certain they get some bright light and varying conditions. I cringe a little at putting anything on a poly finish for quite some time. While they feel dry, they will continue to dry for several weeks. I know on stuff that I have built, that it takes that long for the finish to get to its final hardness.
#6 posted 07-27-2014 03:52 AM
well I thought about it some more, did another test comparison on the back panel and top panel of the clock and decided to use the Howard’s on the whole thing. I am pretty pleased with the results so far, it was very easy to apply, thanks again for the advice! I will post it in the projects when I get it done.
-- Dan
View AnonymousRequest's profile
861 posts in 1483 days
#7 posted 07-27-2014 05:03 AM
I’ve used a lot of the Howards products refinishing antiques. Like what was said above, they work great on old dry wood finishes. The orange oil spray works fine to. I used the Howard wax like above on lacquer finish and actually had better luck with the Johnson, old school, paste wax in a can. For poly I usually wait a bit for it to cure, then lightly sand with 600g, then wax.
View Clint Searl's profile
Clint Searl
1533 posts in 2295 days
#8 posted 07-27-2014 01:07 PM
Johnson’s or Butcher’s is all that’s needed.
