Sanding Pupleheart/YellowHeart End Grain Cutting Board
Forum topic by Brandocalrizzion posted 07-25-2014 11:22 PM 2033 views 0 times favorited 9 replies Add to Favorites Watch
View Brandocalrizzion's profile
Brandocalrizzion
29 posts in 1841 days
07-25-2014 11:22 PM
I am trying to finish my first end grain cutting board. I made it out of Purpleheart and Yellowheart. I had some glue residue left on the wood from the glue up and some saw marks on the wood from the table saw. I am trying to sand it down with my orbital hand sander to get the glue and the saw marks off and having the hardest time working this wood.
I have been using 60, 100, and 180 grit sand paper with my sander. The yellowheart responds much easier than the purple heart does. I have gotten most of it but there is still some pretty good saw marks left on the purple heart and I just can’t seem to get the sander to get that stuff off. I do not want to use my planer with end grain and I do not have any hand planes either. As far as I know, my only option is to continue working it with my hand sander.
Does anyone have any advice for me regarding sanding purple heart? The sand paper gets destroyed pretty quickly and I do not seem to be making much progress. I have about 3 hours sanding into it right now.
9 replies so far
View Arlin Eastman's profile
Arlin Eastman
4258 posts in 2795 days
#1 posted 07-25-2014 11:34 PM
Scrappers are your friend. Also Purpleheart is harder they Yellowheart so it will sand faster.
This is something a lot of people do not know. When I was in Panama, South America they have so much Purpleheart that they burn it like Cottonwood here. Big trees too.
-- It is always the right time, to do the right thing.
View AandCstyle's profile
AandCstyle
3184 posts in 2491 days
#2 posted 07-25-2014 11:41 PM
I have a few suggestions for your consideration. Purpleheart is very hard, but it can be overcome.
The first is to glue a strip of flat grain wood to the back edge of the CB and let the glue completely cure, then run it through your planer taking very light cuts, maybe like 1/64th. The flat grain will prevent the end grain from tearing out. Only try this IF you are very comfortable with the process and your CB is sufficiently thick to take the stress of the planer. A spiral head will work better than blades and feed at the slowest possible setting.
Make a sled and use your router with a bowl bit or similar. Again, take the shallowest possible cuts.
Use 36G paper on your sander. HTH
-- Art
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#3 posted 07-26-2014 01:00 AM
Or take it to a cabinet shop and have them run it through their wide belt or drum sander. It will take minutes to achieve a nice flat/finished surface.
View firefighterontheside's profile (online now)
19580 posts in 2091 days
#4 posted 07-26-2014 01:06 AM
I did my end grain board sanding with a hand held belt sander. They are not very expensive to buy and will remove way more material than a ros. Also the metal base of the sander will prevent the removal of one wood before the other. It’s the soft pad of the ros that allows that to happen.
gfadvm
#5 posted 07-26-2014 01:24 AM
Bill is a WAY better hand with a belt sander than I am! I can ruin a project quicker with a belt sander then any tool in my shop!
View bondogaposis's profile
bondogaposis
5148 posts in 2585 days
#6 posted 07-26-2014 01:41 AM
I can’t help you here but in the future use high quality cross cut blade to eliminate the saw marks and save yourself all of this grief.
-- Bondo Gaposis
Brandocalrizzion
#7 posted 07-30-2014 08:06 PM
Thanks everyone! These are some helpful tips. I think I will pursue seeing if I can find a cabinet shop around town to help me out. That seems like the best means to resolve the conflict with this project and then apply some of this advice to my next cutting board
View CharlesA's profile (online now)
CharlesA
3358 posts in 2032 days
#8 posted 07-30-2014 08:16 PM
If the glue is primarily in depressions created by saw blades, then that is tough to get out. Sorry for that.
In addition to all the other suggestions, an inexpensive block plane can be quite handy for a lot of woodworking operations, including excess glue (though no help in the saw blade depression case).
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#9 posted 07-30-2014 08:20 PM
Hello scraper plane
