Question about small logs
Forum topic by Sawdustmaker115 posted 07-25-2014 04:48 PM 907 views 0 times favorited 1 reply Add to Favorites Watch
View Sawdustmaker115's profile
Sawdustmaker115
306 posts in 1721 days
07-25-2014 04:48 PM
Topic tags/keywords: question
Hello,
Here is my question, so i cut down a small dead birch and am planning to use these as table legs on a project or two, and I probably will use this wood for other things as well like turning and such. So how should i dry these logs out? I put some titebond 2 on the ends to seal it, should I dry these outside for awhile or should I bring them into the shop? They’re about 3-4’’ in diameter and are cut into 2’ sections.
Thanks in advanced for the tips!
-- Anthony--http://knottywoodshop.weebly.com/
1 reply so far
View WDHLT15's profile
WDHLT15
1743 posts in 2476 days
#1 posted 07-26-2014 03:31 AM
They need to dry outside under cover for a while. Bringing them into a climate controlled shop will cause them to dry too fast, and they will split, crack, and check badly. After a couple of months outside under cover like an open sided shed, you can then bring them into the shop to continue drying.
