Sled to crosscut live edge slab
Forum topic by CharlesA posted 07-24-2014 04:49 PM 2700 views 0 times favorited 29 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3319 posts in 1791 days
07-24-2014 04:49 PM
Topic tags/keywords: jig question tablesaw
I’m working on a live edge coffee table with a waterfall leg. That means I need to crosscut the slab with a very clean cut, and then I will need those adjoining edges to be at 45° so I can make the 90° for the leg.
My first thought was a simple crosscut sled with t-track parallel to the blade about 12 inches on each side I could use 4 t-track hold downs like these to keep the irregular piece stable for the table saw cut:
The idea would be that I would make the sled with 45° kerf, make the initial cut, flip the off piece over to the other side and then very carefully make the 45° cut on that side as well.
After I get the cuts straight, I am going to join them with full blind splined miters.
What am I not thinking of? Suggestions?
29 replies so far
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#1 posted 07-24-2014 04:58 PM
It all depends on the width of the table I suppose. My tablesaw sled will handle 24” wide panels. Your clamp idea will ensure that the panel doesn’t move during the operation. Will the sled ride on a metal runner in the TS slot?
View mahdee's profile
mahdee
3883 posts in 1761 days
#2 posted 07-24-2014 05:03 PM
Depending on the thickness of the slab, a circular saw might be a better approach.
-- earthartandfoods.com
CharlesA
#3 posted 07-24-2014 05:04 PM
I was going to use wooden runners and wax them. That works well for me on my usual sled.
I didn’t want to mess up my usual sled with the 45° cut at max height.
CharlesA
#4 posted 07-24-2014 05:06 PM
MrJinx,
My thought was that if I got the sled right, I would bet a more precise cut this way. Why would you favor the circular saw?
mahdee
#5 posted 07-24-2014 05:16 PM
Charles,
The circular saw may provide a better precision since you are moving the saw which is light weight, not the slab, irregular and heavy. By securing a track across the slab, you can easily cut it with a circular saw.
CharlesA
#6 posted 07-24-2014 05:26 PM
gotcha.
CharlesA
#7 posted 07-24-2014 05:35 PM
Looks like the max cut depth for most circular saws at 45° is 1 3/8.” After I finish flattening, I’ll see if that will be sufficient. Doubt it will.
mahdee
#8 posted 07-24-2014 05:48 PM
If you can believe it, the desk I made is 3” thick; after cutting it with the C-saw, I went ahead and cut the rest of it with a hand saw.. Not recommending that as I had to make adjustments with a hand plane. You may want to check into one of these if you plan to make more live edge stuff:
I have the makita. Very intimidating, but amazingly smooth.
http://www.amazon.com/s/?ie=UTF8&keywords=makita+16+circular+saw&tag=googhydr-20&index=tools&hvadid=31574845277&hvpos=1t2&hvexid=&hvnetw=g&hvrand=4906701476510568160&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_8norgsrnzu_b
CharlesA
#9 posted 07-24-2014 06:03 PM
Thanks. I don’t anticipate doing this more than every year or two, when it strikes my fancy.
I’m curious if anyone has actually crosscut a live edge slab with a sled. I’m all ears about the best approach.
View gfadvm's profile
gfadvm
14940 posts in 2684 days
#10 posted 07-25-2014 12:19 AM
Charles, The sled should work fine with the holddowns. The problem I see is deciding where “square” is as both pieces will have to match to create your waterfall joint.
I’m still thinking on this but hopefully a smart guy will chime in!
View timbertailor's profile
timbertailor
1594 posts in 1418 days
#11 posted 07-25-2014 01:13 AM
Using the band saw might make using a sled easier at a 45 degree angle and would insure that you could cut all the way through.
Just not sure if the throat of your band saw has the capacity to use this method.
CharlesA
#12 posted 07-25-2014 04:18 AM
No on bandsaw capacity. I thought about that. Thanks for the thought.
timbertailor
#13 posted 07-25-2014 04:23 AM
- CharlesA
TS75 has a 2.2” depth of cut at 45 degrees and a 30 day money back guarantee? :)
Sorry. I am always looking for an excuse to buy this bad boy!
View AnonymousRequest's profile
AnonymousRequest
861 posts in 1543 days
#14 posted 07-25-2014 11:27 AM
I agree with mrjinx, that’s how I’d do it. Good secure straightedge. I’ve used the 16” Makita circular saw linked to as an carpenter on jobsites. They are a beast.
CharlesA
#15 posted 07-25-2014 01:21 PM
Just checked around—no one rents those big circular saws in Louisville, can’t plop down $700 for a Festool or Makita circular to cut one slab.
showing 1 through 15 of 29 replies
