cutting board wharping ??
Forum topic by grenger posted 07-24-2014 11:33 AM 1126 views 1 time favorited 9 replies Add to Favorites Watch
View grenger's profile
grenger
199 posts in 3570 days
07-24-2014 11:33 AM
Topic tags/keywords: question
Any idea? This board was done over 4 months. Gave it to a friend and it whraped? Made over 60 endgrain This is the first time that this happens
thanks
-- Gerry (the beginner), Gatineau, QC, Canada
9 replies so far
View WDHLT15's profile
WDHLT15
1792 posts in 2680 days
#1 posted 07-24-2014 12:00 PM
I suspect that the wood was not in equilibrium with the environment that the cutting board was being used in. Change in moisture can cause this type of wood movement.
View rrww's profile
rrww
263 posts in 2317 days
#2 posted 07-24-2014 01:48 PM
Maybe they used it on top of that stove when it was still too warm or making a slight amount of steam.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2573 days
#3 posted 07-24-2014 03:19 PM
Did you oil both sides before you gave it to them? If so, perhaps they washed it enough with soap and used it enough to deplete the oils on the top, and the top dried out, while the bottom did not lose oil.
View Yonak's profile
Yonak
986 posts in 1725 days
#4 posted 07-24-2014 03:28 PM
There’s no standard or good way of unwarping a board, unless it’s a temporary warp to start with. How about putting feet on the concave side and making them a new board using equalized wood ?
View harveysoriginals's profile
harveysoriginals
107 posts in 1690 days
#5 posted 07-24-2014 03:30 PM
A friend f mine brought an end grain board to me recently that was at least this bad. He wanted me to “fix” it! I simply laid it on my work bench for 2 weeks and it pretty much flattened out! He could not believe I did nothing to it and I don’t think he will be storing it over his sink anymore! It had been made to fit that sink and even though the guy that made it warned him, he did not properly care for it! It was pretty much wet all the time! Wish I had taken pics but, I didn’t think of that at the time! It had mineral oil and bees wax on it or so he said so it would have messed up a lot of sandpaper!!!!
-- The most dangerous tool in my shop is the one I am currently using! Harvey
View timbertailor's profile
timbertailor
1594 posts in 1628 days
#6 posted 07-24-2014 03:31 PM
I think someone left it standing in the sink over night on its edge with water still in the basin.
View AandCstyle's profile
AandCstyle
3179 posts in 2461 days
#7 posted 07-25-2014 12:35 AM
I had one do that. I think it was because the user washed it, then laid it flat on his counter. The moisture was able to evaporate from the top, but not the bottom. I suggested he stand it on edge until it had completely dried (overnight) and the problem went away. HTH
-- Art
WDHLT15
#8 posted 07-25-2014 01:54 AM
They probably ran it through the dishwasher a number of times…...
View lew's profile
lew
12437 posts in 3959 days
#9 posted 07-25-2014 03:10 AM
My wife left ours set in a puddle of water over night. Next morning, I had an end grain bowl. Put it in the oven on the lowest setting (around 170 degrees) and it flattened itself out after several hours.
