Support for dust collection hose
Forum topic by daviddoria posted 07-23-2014 10:33 PM 1062 views 0 times favorited 5 replies Add to Favorites Watch
View daviddoria's profile
daviddoria
67 posts in 1841 days
07-23-2014 10:33 PM
I’ve got a Delta 760-50 dust collector. I put a trashcan under it with a cyclone lid, and it seems to work well enough (a lot of dust still gets in the bag, but no large particles). I split the hose coming from the trashcan (4”) to run to a table saw and a planer. Each of these split hoses has a blast gate. However, as you can see in the picture, the whole setup is quite “droopy”. That is, it seems like there is a lot of stress on the joint between the hose and the cyclone lid from the weight of the hose hanging down, especially with the splitter and blast gates attached.
Should I worry about this/try to fix it? I’m sure the 180 degree turn (from up to down) the hose makes is not good for the airflow. Would anyone recommend that I build some kind of support for the hose/splitter on/near the collector?
Thanks!
David
5 replies so far
View DIYaholic's profile
DIYaholic
19536 posts in 2578 days
#1 posted 07-23-2014 10:37 PM
I would bungee the “Y” fitting to the trash can handle, as a temporary support….
Then do whatever is needed to eliminate sharp bends.
Shawn Masterson
1324 posts in 1851 days
#2 posted 07-24-2014 01:08 AM
eliminate as much flex as possible. It is killing your system. by going with hard pipe you will have smoother transitions, better flow and velocity. 4”pvc is not that expensive.
daviddoria
#3 posted 07-24-2014 10:30 AM
Shawn – even if I switch to pipe, I will have the same question of “how do you support the heavy pipe coming off the lid?”
Does anyone have pictures of their solutions?
View WhyMe's profile (online now)
WhyMe
978 posts in 1464 days
#4 posted 07-24-2014 02:42 PM
I used a 4” pipe hanger for a support.
View toolie's profile
toolie
2105 posts in 2531 days
#5 posted 07-26-2014 12:20 PM
and add a thien baffle to that cyclone lid. it will dramatically improve it’s performance.
