Glue
Forum topic by diverlloyd posted 07-23-2014 05:33 PM 1763 views 0 times favorited 24 replies Add to Favorites Watch
View diverlloyd's profile
diverlloyd
2737 posts in 1858 days
07-23-2014 05:33 PM
Jocks what is the best temporary glue. Like for glueing up multiple pieces to be stack cut. I’m not a fan of double stick tape so I use glue but the drying time seams like wasted time. So any good fast temporary glues out there.
24 replies so far
4987 posts in 2494 days
#1 posted 07-23-2014 05:35 PM
Would a couple of drops of hot melt glue from a glue gun work for what you want?
diverlloyd
#2 posted 07-23-2014 06:09 PM
Maybe, I will have to give it a try.
diverlloyd
#3 posted 07-23-2014 10:44 PM
hot glue was a no go. I guess it will be titebond III and lots of drying time. That blows
View timbertailor's profile
timbertailor
1594 posts in 1425 days
#4 posted 07-23-2014 10:57 PM
Elmer’s makes a spray adhesive that works for some projects.
Easy to remove but will need resanding.
diverlloyd
#5 posted 07-23-2014 11:00 PM
thanks I thought about using plain old elmers white glue or a paste glue stick. but the spray may be the way to go.
TopamaxSurvivor
18272 posts in 3676 days
#6 posted 07-23-2014 11:07 PM
If you glue, use a sheet of paper between the layers to make parting easier. They say hide glue is reversible in other threads , but I have never done it.
View CFrye's profile (online now)
CFrye
10193 posts in 1840 days
#7 posted 07-23-2014 11:15 PM
AJ, what issues do you have with the tape?
Have you tried screws in the waste areas?
-- God bless, Candy
View mudflap4869's profile
mudflap4869
1737 posts in 1460 days
#8 posted 07-23-2014 11:16 PM
If you project can take the heat Tightbond will often fail if are liberal with the glue and get the wood hot enough after the cutting is done. I have had success with that in the past. Still have to sand it though.
-- Still trying to master kindling making
diverlloyd
#9 posted 07-23-2014 11:18 PM
Topamax I will try the paper I have been using 1/8” painters tape about 1/16” from the edge. I have used this method on I guess about 30 drunken alice cutting boards but its so time consuming to mask then waiting for the glue to dry. I don’t mind the waiting it just seems the time could be better spent on the project but you really cant do much when waiting for it to dry. Hope your migraines are better mine are down to 4 days a week.
diverlloyd
#10 posted 07-24-2014 12:20 AM
The price of the double stick tape is absurd. Oddly enough I found a heat gun in its box in a box that I bought at auction for a dollar,so I will try the heat gun since I don’t care about the strength.
View Wildwood's profile
Wildwood
2306 posts in 2135 days
#11 posted 07-24-2014 12:46 AM
I have had good luck with hot glue while turning stuff. Burnt myself with glue gun or hot glue dripping out of the gun too many times. So use a propane torch to melt the glue and use light pressure for about thirty seconds to a minute. Use a cabinet scrapers & sandpaper to remove glue.
Have also use carpet double sided tape from the big box stores. Still have most of the roll left.
-- Bill
View CharlesA's profile
CharlesA
3323 posts in 1798 days
#12 posted 07-24-2014 01:21 AM
You can find some pretty cheap carpet tape.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=double+stick+tape+carpet&rh=i%3Aaps%2Ck%3Adouble+stick+tape+carpet
http://www.amazon.com/Double-Sided-Carpet-Tape-Long/dp/B009AEPY30/ref=sr_1_9?ie=UTF8&qid=1406164806&sr=8-9&keywords=double+stick+tape+carpet
Wildwood
#13 posted 07-24-2014 11:31 AM
Charles, most big box stores have the same products for same price or less. Now know Lowes has big assortment of double sided tape with different strength holding abilities.
This is the stuff I used, on a couple turning projects had to scrap and sand surface when done. Know harder cleaning glue residue off a floor when replacing carpets where cannot scrap and sand.
http://www.lowes.com/pd_256882-14510-280396_0__?productId=3407976&Ntt=dpuble+sided+carpet+tape&pl=1&currentURL=%3FNtt%3Ddpuble%2Bsided%2Bcarpet%2Btape&facetInfo=
Know from reading other posts over the years double sided carpet tape get mixed reviews by woodworkers. Stuff either works for a project or it doesn’t.
-- Bill
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#14 posted 07-24-2014 12:59 PM
I use the carpet seaming tape. Great holding power. Use Acetone or lacquer thinner to release.
Not a time saver though, when release and clean up is factored in.
diverlloyd
#15 posted 07-24-2014 01:16 PM
Thanks for the replies jocks. Has anyone used rice glue like is used for Japanese sword scabbards.
