Finishing Cherry with GF Arm R Seal
Forum topic by paxorion posted 07-23-2014 02:41 PM 3426 views 0 times favorited 8 replies Add to Favorites Watch
View paxorion's profile
paxorion
1107 posts in 1919 days
07-23-2014 02:41 PM
Topic tags/keywords: question finishing
I’m planning on trying out satin GF Arm-R-Seal for my pepper mill turning. For the application, I have had good success with a wipe-on approach and plan on doing the same. To maximize the Woodcraft sale this weekend, I do have a few questions I am hoping to get some guidance on:
  1. Given that the project is cherry, would you recommend a coat of GF Seal-A-Cell first or should I jump straight to the Arm-R-Seal alone?
  2. I am planning on putting on 2 coats, but am curious if I should consider more coats for a more durable finish.
  3. For a wiping approach on Arm-R-Seal, have you found that thinning with mineral spirits is required? If so, what sort of ratio do you recommend?
-- paxorion
8 replies so far
View wncguy's profile
wncguy
353 posts in 2186 days
#1 posted 07-23-2014 03:12 PM
I’ve used the satin Arm – R – Seal (no sealer) on most of my boxes. I’ve done several boxes with wood glue ups that include cherry, however, I should note the cherry did not have any figure to it. I typically wipe on 4 coats. You can check my projects to see some examples.
Been happy with the results.
One thing I’ve found is that be careful not to use the ARS from the can, put what you think you’ll need into another container, then don’t contaminate the ARS by pouring unused finish back in the can. Next I float (carefully spray) some ultra duster into the can before closing.
I think I can post a link to a post I did a while back…
http://lumberjocks.com/topics/61070
-- Any man can be a father, but it takes someone special to be a Dad
paxorion
#2 posted 07-23-2014 05:46 PM
I ve used the satin Arm – R – Seal (no sealer) on most of my boxes. I ve done several boxes with wood glue ups that include cherry, however, I should note the cherry did not have any figure to it. I typically wipe on 4 coats. You can check my projects to see some examples.
One thing I ve found is that be careful not to use the ARS from the can, put what you think you ll need into another container, then don t contaminate the ARS by pouring unused finish back in the can. Next I float (carefully spray) some ultra duster into the can before closing.
- wncguy
Very nice. I’m curious about your application approach; brush or wipe? It also sounded like you used it without thinning?
-- paxorion
wncguy
#3 posted 07-23-2014 07:14 PM
Wipe. No thinning. I’ve found it’s pretty “thin” right out of the can.
Over time the used can might require some thinner (I think it’s mineral oil that’s recommended by GF) as I’ve seen it can be a little more viscous.
View JohnDi's profile
JohnDi
22 posts in 1307 days
#4 posted 07-23-2014 11:07 PM
I use an old T-Shirt and wipe on. Have never been disappointed with Arm-R-Seal satin on cherry.
[IMG]http://i1298.photobucket.com/albums/ag52/johndi1/b7f1b78a7504f62d0bd46d86b046d5dc_zps1f4e3ee4.jpg[/IMG]
View Domer's profile
Domer
252 posts in 3240 days
#5 posted 07-24-2014 03:48 PM
I use Amr-R-Seal on about everything I finish. I have occasionally used Watco under the Arm-R-Seal to even out the color and then top it with the Arm-R-Seal. Lately, I have just used the Arm-R-Seal with good results.
I apply it with paper rags from Home Depot. I find them to have less lint than old T-Shirts. I spread the rags on the floor to dry overnight before tossing them.
I always use at least 3 thin coats on what ever I am finishing If I want a particularly durable finish or if for some reason, I have had to sand out an area, I have used up to 5 coats.
Usually, I buy it in the plastic gallon containers and pour it into small plastic glasses to apply. I put the left over Arm-R-Seal back in the plastic container and squeeze the container so there is little to no air at the top. I have never had a problem with the Arm-R-Seal going bad with this method. I think it works better than buying it in quarts. Less expensive and less waste.
Domer
paxorion
#6 posted 07-28-2014 12:59 AM
I’ve had a chance to use the Arm-R-Seal and will have to say, I am truly a believer in it now. So far, I’ve put on 4 coats and it definitely lives up to the “hype”. The biggest benefit, is the fact that it has such a low odor, that I was able to do the wiping application in my basement without stinking up the entire house. Not to say that I will be applying it non-stop in-doors, but it is still nice to have the option.
-- paxorion
View timbertailor's profile
timbertailor
1594 posts in 1297 days
#7 posted 07-28-2014 02:19 AM
Do not use a sealer typically with Maple or Cherry.
I use coffee filters to wipe it on. No lint, good size, and cheap. Really keeps me from applying too much at one time.
The fewer the coats I can get away with on a project, the better. I feel it leaves a more original color to the wood.
View ScottKaye's profile
ScottKaye
559 posts in 1826 days
#8 posted 07-29-2014 12:55 PM
Coffee filters.. hmm. that’s a good idea. Going to have to try that one. I have been experimenting with arm-r-seal and so far have found that taking a folded up wiping cloth (sold at Home Depot under that name) and placing it in an old pair of my wife’s nylons and cutting and tying the end off, gives a wonderfully smooth, lint free even finish. *Note the nylon/wiping cloth pad per se is smaller than handball and larger than golf ball.
-- "Nothing happens until you build it"
