Jet 250s supersaw left side table
Forum topic by theoriginaltree posted 07-23-2014 02:06 PM 2044 views 0 times favorited 9 replies Add to Favorites Watch
View theoriginaltree's profile
theoriginaltree
5 posts in 1637 days
07-23-2014 02:06 PM
Hello everyone
Hopefully I have posted this in the right place following the guides!!
I am in the UK and looking for a left side extension table (with a mitre slot) for my Jet 250s / supersaw. Does anyone know if these are still available in the USA?
It seems these are no longer available in the UK and I would like one as I dont get on with the sliding table. I’d like to use a cross cut sled again.
Heres hoping!!
Regards
Paul
9 replies so far
View timbertailor's profile
timbertailor
1594 posts in 1658 days
#1 posted 07-23-2014 04:20 PM
Hello everyone
It seems these are no longer available in the UK and I would like one as I dont get on with the sliding table. I d like to use a cross cut sled again.
Heres hoping!!
Regards
Paul
- theoriginaltree
Could you pull some replacement part numbers from your manual. I can check their system with that if you have not already tried it.
I am not optimistic. I think they stopped making them in mid 2000.
theoriginaltree
#2 posted 07-23-2014 07:47 PM
Hi Brad
Many thanks for replying.
I have a few different part numbers:
The Jet part number for the saw is 708781KM.
There is also a code of 200398 in my manual for the left wing with the mitre slot.
I also have a code of: Jet000311, but I think this is a UK code.
Many thanks!
timbertailor
#3 posted 07-23-2014 08:23 PM
Hi Brad
Many thanks!
- theoriginaltree
Not much luck. The only hit I got was not even close. I tried.
JSJ214C-000311 ACTUATOR $2.95 Limited Quantity
You searched for the Part Number: 200398
Parts
There are 0 parts available online that match your search.
Here is what it is called here in the states.
Extension Wing w/Miter Slot-L
Part Number: 200398
Jet
Availability: Discontinued
theoriginaltree
#4 posted 07-24-2014 08:00 AM
Many thanks for checcking Brad!! Much appreciated.
View Laughran's profile
Laughran
79 posts in 2162 days
#5 posted 07-24-2014 09:30 AM
I have a Jet Supersaw with sliding table and attached a crosscut sled to the sliding table.
It works really well.
-- David
theoriginaltree
#6 posted 07-24-2014 10:34 AM
Hi David
Do you have any pics? I would be interested to see how you achieved this.
Have you got your sliding table running true and level with the main table? As I understand it, it should be a mm above the main table. Mine is all over the place at the minute!
Laughran
#7 posted 07-25-2014 10:27 AM
I will try to post some pictures this weekend.
-- David
Laughran
#8 posted 07-27-2014 09:33 PM
I posted my sled and tablesaw under projects for you to see.
-- David
theoriginaltree
#9 posted 07-28-2014 06:38 AM
Thats great!! Many thanks for sharing David
