Blemishes on ipe
Forum topic by Eric posted 07-23-2014 03:35 AM 795 views 0 times favorited 2 replies Add to Favorites Watch
View Eric's profile
Eric
7 posts in 1433 days
07-23-2014 03:35 AM
I have several spots where the natural oil in the ipe has been squeezed to the surface by the pressure of the clamps during glue up. This creates a darker circular mark where the clamp pad was. I have seen this happen before when I clamped the wood while routing the tenons and it eventually faded away but it took a while. I am leery of sanding and applying my oil sealer with these spots still visible. Any suggestions? Have u seen this happen before?
-- Living like no one else to later live like no one else
2 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3740 days
#1 posted 07-23-2014 04:49 AM
Would alcohol, mineral spirits or acetone remove the oils well enough to get rid of the oily patch?
View Ted's profile
Ted
2873 posts in 2239 days
#2 posted 07-23-2014 06:12 AM
Clean it with solvent as Mark says. If the dark spots still remain it means the fibers have been compacted, in which case raising the grain with hot water might even it out.
With oily woods such as ipe, I clean the oil from all surfaces with acetone or alcohol just before finishing. Mineral spirits or paint thinner also works but I don’t like waiting for it to dry. With especially oily wood that’s often enough time for the oils to wick back to the surface, which kind of defeats the purpose.
Welcome to Lumber Jocks! :)
-- You can collect dust or you can make dust. I choose to make it.
