Best cheap table saw fence?
Forum topic by SouthernWoodworking posted 07-23-2014 03:35 AM 3457 views 0 times favorited 12 replies Add to Favorites Watch
View SouthernWoodworking's profile
SouthernWoodworking
92 posts in 1431 days
07-23-2014 03:35 AM
Topic tags/keywords: question tablesaw
So, I need a new table saw fence. What are some good ones? I saw the Delta T2 but its very expensive. Its going on a old craftsman.
-- Noah Lambert, Georgia, 2x2 Designs.
12 replies so far
View eatsawdust's profile
eatsawdust
35 posts in 2257 days
#1 posted 07-23-2014 03:44 AM
If the T2 is too expensive you probably won’t find a good one less than that, I would take a look at the Grizzly aluma classic I was considering it but held out until I could just afford to buy the Classic fence. I’m pretty sure the price is at least as much as the T2 for the aluma classic, So I doubt this will help much. The fence is the most important part of the saw its worth replacing it with quality. I did lots of research because I am a penny pincher I just couldn’t come up with a better option for less. Good luck
-- Why does everything I enjoy doing have to be bad for the environment, I work in the oil industry and enjoy working with exotic woods from rain forests
View LarryT's profile
LarryT
17 posts in 2071 days
#2 posted 07-23-2014 03:52 AM
I recently replaced the horrible fence on my craftsman saw with the Delta T2. Cost was about $170 as I recall.
Seems that it used to be considerably cheaper but that was about the best I found. I wasn’t quite as easy as
I had thought from several on line reviews of this upgrade but with a bit of fiddling and careful drilling it
went on and is so much better it is like a diferent machine.
View JeremyT21's profile
JeremyT21
60 posts in 1460 days
#3 posted 07-23-2014 07:36 AM
I’ve been looking for a new fence for my old craftsman also. From what i’ve found, the Vega fence seems to be the best deal. Also many people have reported it bolts onto the existing hole in the craftsman saws. In the mean time, I have found that adjusting the crappy fence from the T portion instead of grabbing it in the middle greatly helps get it square to the blade. Since I started adjusting it that way, I rarely have to do any other adjustments once I set it the first time.
-- www.rockytoptimber.com
View knotscott's profile
knotscott
8008 posts in 3370 days
#4 posted 07-23-2014 09:21 AM
The T2 represents one of the best bangs for the buck going, so if it’s expensive, the remaining options are used or homemade. Watch CL for a deal on a saw with an Align-a-rip fence or similar Ridgid, then sell the saw it came with or yours….those are a distinct step up from the old steel Emerson fences. Maybe you’ll find a used Biese, Shop Fox, or Vega fence….
If you could get a saw like this down to ~ $200, you could probably sell your old saw for ~ $100-$125 if you clean it up nice. Total cost $75-$100.
http://atlanta.craigslist.org/nat/tls/4551781288.html
SouthernWoodworking
#5 posted 07-23-2014 02:38 PM
Ok, So with all that, I may just have to bit the bullet and get a T2. My CL doesnt seem to sell any table saw fences.
View johnstoneb's profile
johnstoneb
2911 posts in 2167 days
#6 posted 07-23-2014 02:44 PM
Cheap and good are mutually excusive when it comes to fences. The T2 makes a completely different saw out of the craftsman. You can actually make square and straight cuts.
-- Bruce, Boise, ID
SouthernWoodworking
#7 posted 07-23-2014 02:48 PM
- johnstoneb
I can make a square cut now, just takes 2min for each cut to align the blade to the fence :D hahaha
View timbertailor's profile
timbertailor
1594 posts in 1419 days
#8 posted 07-23-2014 08:35 PM
I would do some more homework. You can get very inexpensive 36” pieces of extruded aluminium fence material for around $35 shipped. If you have a way to secure it to your existing fence locking system, or find one that suits your goals, and you are set.
May take some creative blood to go this route, but it can be inexpensive.
SouthernWoodworking
#9 posted 07-23-2014 08:57 PM
- timbertailor
Well I dont have a way to secure it. Could you post a link to someone who did this cause Im not able to find someone who did this for cheap.
View lynn1953's profile
lynn1953
3 posts in 1788 days
#10 posted 07-23-2014 11:18 PM
I put a t-2 on my old craftsman. It and a couple of quality blades and link belt made a huge difference. Take time and install it right and you wont regret it. There are posts around on how to do it. You will have to grind the back rail to make the saw tilt a full 45 deg. I learned the hard way on that. The saw is so much better now. I pulled the tape measure,off,and,repositooned,it,so its,dead,on now.
View Bill White's profile
Bill White
4928 posts in 3955 days
#11 posted 07-23-2014 11:34 PM
“Best” and “cheap” are mutually exclusive. Ain’t no such animal.
My Incra 1000SE is all I’ll ever need, but ya get what ya pay for.
Don’t wanna sound snotty, but it is what it is.
Bill
-- bill@magraphics.us
timbertailor
#12 posted 07-24-2014 12:01 AM
- SouthernWoodworking
You are correct. If you have to pay someone else to do it, it will not be cheap.
VerySuperCoolTools
These guys made some videos some years ago on how to make this fence before they opened up this business. Was not real detailed but you may still be able to find it.
P.S. It is still in their video library.
