HELP WITH CLUE-UP
Forum topic by JUC posted 07-21-2014 08:54 PM 860 views 0 times favorited 3 replies Add to Favorites Watch
View JUC's profile
JUC
116 posts in 2068 days
07-21-2014 08:54 PM
I am making my first cutting board and need some glue up help. I am using 6/4 maple about 6” wide. Is it better to cut the 6” wide board down to some 2”wide strips and glue them together or is it ok to just glue the 6 boards together?
Thanks for your help!!
Jeffrey
-- If no one will ever see it, all the more reason to make it right
3 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2547 days
#1 posted 07-21-2014 09:16 PM
Assuming your board isn’t quartersawn, you’ll get a more stable board from cutting the strips, flipping them on edge, and gluing them back together. A 6” wide board will me more likely to cup on you across the growth rings. Making an edge grain board such that the growth rings run more top-to-bottom than side-to-side helps with this. Edge grain also helps resist knife marks more than face grain, but less than end grain.
You could get a contrasting wood like cherry or walnut and put strips of those in between the maple for a decorative touch.
View JoeinGa's profile
JoeinGa
7739 posts in 2184 days
#2 posted 07-21-2014 09:17 PM
If you rip the 6” boards down you could “mix – n -match” the grain patterns to make it more interesting. MAybe use some dark strips of other woods between the maple for contrast?
View JUC's profile
JUC
#3 posted 07-22-2014 01:08 PM
Thank you for your help.!! That helps me understand several things I was thinking about.
Jeffrey
