Question about restoring Stanley 9 1/2 block plane
« back to Hand Tools forum
Forum topic by JohnSR posted 07-20-2014 11:25 PM 1186 views 0 times favorited 5 replies Add to Favorites Watch
View JohnSR's profile
JohnSR
9 posts in 1430 days
07-20-2014 11:25 PM
Topic tags/keywords: question hand plane
So I picked up a hand plane for 2 dollars at a flee market but it does not have a blade (Iron?) only markings on it are England and CF 16 found a website that says its the same as a Stanley 9 1/2. I need hand planes and I dont have much to spend would it be economical to get a new Iron for this or just junk it and see if I can find another block plane somewhere? Also, if it is worth it to find an Iron do I buy a new one or find one on Ebay that was originally for this plane?
-- John, San Diego
5 replies so far
View Don W's profile
Don W
18686 posts in 2537 days
#1 posted 07-20-2014 11:28 PM
you can buy a replacement “cutter” at Home depot for about $3. And believe it or not, they are pretty good.
JohnSR
#2 posted 07-21-2014 02:15 AM
Ok so as far as I can tell the 9 1/2 takes a 1-5/8 inch cutter I see it at home depot for 7.72 http://www.homedepot.com/p/Stanley-1-5-8-in-Block-Plane-Cutter-12-331/203950225 is there anything else I need to be aware of when I purchase or are they pretty standard and I will hone it to whatever the guide I find tells me to when I start cleaning it up?
-- John, San Diego
View Pezking7p's profile
Pezking7p
3217 posts in 1621 days
#3 posted 07-21-2014 02:16 AM
John, yah pretty much. And the guide will likely be DonW’s. Check out his plane restoration guide on his website.
-- -Dan
JohnSR
#4 posted 07-21-2014 02:22 AM
Thanks a lot for the info guys, I was not sure if I should get it without a blade but what the heck it was 2 bucks saved me 20 bucks or so over buying a new one off amazon.
-- John, San Diego
View sikrap's profile
sikrap
1121 posts in 3329 days
#5 posted 07-22-2014 01:43 PM
You’ll be in good shape honing anywhere from 25-30 degrees. Don’t forget to flatten/polish the back of the new iron. Also, you should keep an eye open for a low angle block plane for end grain :))
-- Dave, Colonie, NY
