11/2” legs from ¾” stock for a Greene & Greene table
Forum topic by newwoodbutcher posted 07-20-2014 02:47 AM 1348 views 0 times favorited 14 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
730 posts in 2758 days
07-20-2014 02:47 AM
I’m building a skirt and legs for a table top I’ve had banging around the shop since making it in a veneering class project 4-5 years ago. Low and behold after all that time, my wife want’s an end table “just like that shop class thing” I made. Perfect. It’s mostly walnut 191/2” X 191/2” X 3/4”. I’m building walnut skirt and legs, Greene and Green inspired, Cloud lift and ebony plugs and indented leg. I’ve got a pile of rough walnut but nothing that will yeild much more than ¾” material. What I need help on is making the 11/2” legs with ¾” stock. I can’t see me being happy with a visible figure seam on these legs. I’ve been combing through my book and magazine collection. I’m sure I saw a flurry of articles on this topic several years ago. No luck. I’m thinking of bevel ripping all four sides to wrap the figure. Is there a better/smarter way to do this?
-- Ken
14 replies so far
View Loren's profile
9970 posts in 3555 days
#1 posted 07-20-2014 03:28 AM
Resaw thick veneers and glue over the ugly face, or all
the faces if you want. For that matter, you can make the
legs out of poplar and veneer.
View MNgary's profile
MNgary
296 posts in 2325 days
#2 posted 07-20-2014 03:53 AM
I want to make sure I understand the problem. You have 3/4 inch boards and you want to glue them together until 5-1/2 inches (11/2 inches in your post) thick for the table’s legs, but without anyone knowing they were glued up.
Guess you’re going to have to paint them.
-- I dream of the world where a duck can cross the road and no one asks why.
View RazedGrain's profile
RazedGrain
16 posts in 1879 days
#3 posted 07-20-2014 04:43 AM
There’s a technique using lock miter or whatever router bits in FWW # 121. Essentially to do as you describe but much easier to glue up the miter. Or I suppose you could spline the corners.
Seems like it would take longer than to just veneer the seam face, very thin like 1/8” or less, be hard to see from the side if you pick the grain right.
2cents.
-- - Jeff - Hamilton, ON, Canada
View jmartel's profile
jmartel
7687 posts in 2058 days
#4 posted 07-20-2014 04:52 AM
I think he means 1 1/2” and just didn’t include the space.
As loren said, glue 2 sides together and add a veneer to the 2 faces that show the lamination. Put a chamfer on each corner that is the same thickness as the veneer and you won’t be able to tell.
newwoodbutcher
#5 posted 07-20-2014 05:27 AM
Thank you. Yes the legs will be 1 1/2” square.
-- Ken
newwoodbutcher
#6 posted 07-20-2014 05:31 AM
I’ve read that the locking miter bit is a bear to se up. I have one but bnever used it,
-- Ken
#7 posted 07-20-2014 05:40 AM
I think a lock miter approach would be better suited
when the legs are 3” square or bigger.
View rmac's profile
rmac
206 posts in 2968 days
#8 posted 07-20-2014 07:03 AM
I took me a long time to realize this, but the materials cost for almost any hobby woodworking project is so much less than the value of the time you’ll spend on it that it just doesn’t make sense to skimp on the materials. So I’d say don’t compromise your project. Save your 3/4” walnut for projects where you need 3/4” walnut, and buy some thicker stock for your table legs.
—Russ
-- My table saw laughs at hot dogs. http://thesorteddetails.blogspot.com/
newwoodbutcher
#9 posted 07-20-2014 06:20 PM
Russ, That was/is my original thought.
-- Ken
View pintodeluxe's profile
pintodeluxe
5568 posts in 2721 days
#10 posted 07-20-2014 07:07 PM
I would glue planks together, then cover the joint with 1/4” thick veneers. Once the leg blank is constructed (made from a total of 4 pieces), you can plane it down to 1-1/2” square.
Here are the details…
http://lumberjocks.com/pintodeluxe/blog/38733
View bannerpond1's profile
bannerpond1
397 posts in 1806 days
#11 posted 09-30-2014 12:12 PM
I don’t believe you will be happy with the legs made from glued-up boards. I suggest you bite the bullet and go find some rift-sawn wood. Look at the end grain and cut your leg blanks so that the growth rings are 45 degrees to the four faces. Only then will you have even grain all around. In addition, you will have the most stable wood.
You will regret trying to put second-rate legs under your nicely veneered top.
-- --Dale Page
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#12 posted 09-30-2014 12:45 PM
You are not going to need much stock to make four legs for an end table, why not pick up some 8/4 walnut and make your life easier?
-- Bondo Gaposis
View Mark Kornell's profile
Mark Kornell
1169 posts in 2438 days
#13 posted 10-01-2014 03:25 AM
Plus, if you are doing the tapered indents on the legs, the thin veneer on two sides approach won’t work.
-- Mark Kornell, Kornell Wood Design
newwoodbutcher
#14 posted 10-01-2014 05:43 AM
Thank you all. I now realize that getting 8/4 material is the best solution. I don’t think I’ll be happy with anything else
-- Ken
