How to Cut Dadoes for Drawer Bottoms on the Table Saw
Forum topic by MT_Stringer posted 07-17-2014 03:13 AM 3418 views 0 times favorited 6 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3173 posts in 3348 days
07-17-2014 03:13 AM
Topic tags/keywords: tip tablesaw dado blade
No, this is not a question. It is simply a description of my efforts to make dadoes for drawer bottoms.
I am building 14 drawers which will have 1/4 inch bottoms using birch plywood from the big box store. I can’t remember where I read about using circular saw blades, but that is what I did and the results were great.
I bought a pair of regular 24 tooth 7 1/4 inch blades (general construction) at the big box store. I added a couple of shims and VOILA!, a plywood dado blade setup! It only took two tries to get the desired width, which allows just enough space for the panel to slide into the drawer stock.
I also made some crosscuts in the drawer sides, but the cuts weren’t real smooth. A little sanding took care of that. I would imagine a pair of blades with a lot more teeth would be better for the cross cuts.
But for ripping, the dadoes were smooth. And as you can see in the picture, I marked the shims so I can do this again in the near future for the last eight drawers.
Hope you find this info helpful.
Note: I do have a router bit made for undersize plywood, but this table saw method is just too easy.
Mike
View OldWrangler's profile
OldWrangler
731 posts in 1711 days
#1 posted 07-17-2014 03:22 AM
I also use the table saw but only 1 1/8” thick blade. I set the fence twice and make 2 passes each 1/8” wide and the 1/4” plywood fits fine since, like everything else in wood, the 1/4” plywood is some 1/32” undersize.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
MT_Stringer
#2 posted 07-17-2014 03:29 AM
- OldWrangler
Yes sir, I have done that too. Never again. Set the fence once and git-after-it! :-)
View johnhutchinson's profile
johnhutchinson
1243 posts in 1746 days
#3 posted 07-17-2014 09:18 AM
Hey Mike,
You might have read about it here. http://woodgears.ca/shop-tricks/dado.html
Matthias goes into a fair amount of detail and talks about the pros and cons.
-- John - Central Ohio - "too much is never enough"
View Roger's profile
Roger
20938 posts in 2921 days
#4 posted 07-17-2014 01:12 PM
A different approach, and, hey, it works. Good one
View Knothead62's profile
Knothead62
2584 posts in 3078 days
#5 posted 07-17-2014 01:46 PM
One blade- I mark the outer edges and cut those first. Measure to ensure that the dim’s are correct. Then I just pass the wood over the blade several times by adjusting the fence. Clean up with a wood chisel if needed.
View cabmaker's profile
cabmaker
1740 posts in 2926 days
#6 posted 07-17-2014 11:19 PM
Dado ?
