water based poly over danish oil?
Forum topic by JesseTutt posted 07-16-2014 05:35 PM 1846 views 0 times favorited 1 reply Add to Favorites Watch
View JesseTutt's profile
854 posts in 2042 days
07-16-2014 05:35 PM
Topic tags/keywords: danish oil poly water based poly question
Several weeks ago I applied Watco’s Danish oil on a maple fixture intended for use in my shop.
With this week’s cool weather I am planning on spraying some wb poly on another item.
Will wb poly go over danish oil after it has been drying for over three weeks? Is there anything I need to consider?
1 reply so far
View Lifesaver2000's profile
551 posts in 3044 days
#1 posted 07-16-2014 06:51 PM
I have applied WB poly over Watco Danish Oil several times, waiting at least a week for the Watco to cure. The oldest item is about three years old and there have been no problems.
Some will say you should not put WB over an oil, but as long as the oil is fully cured there should not be a problem. The poly I use even says as much.
