Dust collection on all or some machines
Forum topic by MrRon posted 07-15-2014 04:30 PM 1214 views 0 times favorited 13 replies Add to Favorites Watch
View MrRon's profile
MrRon
4717 posts in 3209 days
07-15-2014 04:30 PM
I put DC only on machines that create fine dust, like sanding machines. Other machines, like drill presses, bandsaws, jointers/planers make chips, so I don’t run DC ducts to them. I find that you can never get every bit of sawdust, so I have to sweep anyway. I have DC on my floor saw because some woods can burn and produce smoke, but for all other machines, it’s just as easy to clean up with a broom and dust pan. How do others feel about the way I do it?
13 replies so far
4954 posts in 2459 days
#1 posted 07-15-2014 04:53 PM
I’d say if your satisfied with your routine, you should stick to it and not look back. I run DC to all my tools (except the DP) but that’s just me.
View Loren's profile
10262 posts in 3613 days
#2 posted 07-15-2014 05:06 PM
I usually have shavings all over the place. I have 2 dust collectors and
I do try to use them. I also hack stuff up on the bench a lot
so that makes a mess.
Really I only use DC on the table saw, band saw, planer, panel
saw and the sanders. I’d like to have it on everything but
I don’t have the room to have everything fixed in place, and a
big DC with enough suction to really make a clean shop is noisy.
View Manitario's profile
Manitario
2629 posts in 2848 days
#3 posted 07-15-2014 06:06 PM
If you don’t think your jointer/planer/bandsaw produces fine dust, just get a particle counter and set it up in your shop when you run those machines. You’d be surprised how much fine dust they produce.
View Mark Davisson's profile
Mark Davisson
597 posts in 3283 days
#4 posted 07-15-2014 07:03 PM
I find that sweeping chips can be very therapeutic, and gives me a chance to think on a different (but very productive) level every hour or so.
I might recommend a floor sweep for your collector. I don’t mind sweeping, but I don’t like the whole dust pan thing – I usually spill half the pan before I get it into the trash bag/can. Not only that, but my granddaughter loves using it and she’ll do some sweeping for me just to see the chips getting sucked into it.
-- I'm selfless because it feels so good!
View English's profile
English
642 posts in 1443 days
#5 posted 07-15-2014 07:33 PM
I have DC on every tool, with at least a 4” port, most have multiple 4” ports. and I still find fine dust settling on work surfaces all around the shop. I try to remember to set a box fan with filters close to the machines I am using to pull that fine dust away from me and maybe catch some of it.
I need to install a whole shop air cleaner, but ain’t got there yet. After I run a lot of wood through one of my machine I let my big DC run for 30 minutes at least.
-- John, Suffolk Virgina
View Dallas's profile
Dallas
3599 posts in 2452 days
#6 posted 07-15-2014 08:08 PM
Bandsaw, planers and table saw for the collector. I haven’t figure out a way to add it to my DP easily.
I also have a home made air cleaner and dust collector that I use a pair of 20X20 Merv 15 filters on. I change them at least once a month and usually they need it badly.
It has drastically reduced the amount of dust in the (former) shop. Wife is happy because our heat pump shares intake in the house and the shop. She now only vacuums and dusts once a month instead of every day.
View JAAune's profile
JAAune
1788 posts in 2282 days
#7 posted 07-15-2014 08:22 PM
I don’t care for cleaning shop or working in a dusty shop. We have dust collection on most machines but it’s still not enough since it’s a dusty bag system and most ductwork to machines limits CFM due to 4” ducts. Eventually once more important purchases are done, I’ll run a 5HP ClearVue with 6” ducts to all the major equipment.
Shawn Masterson
1325 posts in 1914 days
#8 posted 07-16-2014 02:18 AM
Planers make lots of fine dust, and shavings. you really don’t see it unless you are planing a lot material. when I used my belsaw I would see the haze after a long run.
View bigblockyeti's profile
bigblockyeti
5093 posts in 1686 days
#9 posted 07-16-2014 02:51 AM
For now I have a roll around collector that I attach to each machine as needed. The planer is a must as it creates a substantial quantity of chips that otherwise would be too time consuming to sweep up. It usually stays connected to the tablesaw as it’s used more than any other tool. For hand held sanders I connect a vacuum when that’s an option, when not a mess ensues and a good dust mask is a must.
View Paul's profile
Paul
721 posts in 1530 days
#10 posted 07-16-2014 03:11 AM
My shop is in a basement that shares space with the central ac and heat units, if I didn’t have dc on all my equipment it would be all over the upper 2 floors. With how much dc mods and talk that goes on here I’m surprised that a lot still use a broom and dust pan.
Paul
View TheFridge's profile
TheFridge
9249 posts in 1451 days
#11 posted 07-16-2014 03:27 AM
You have dust collection?
So do I.
It’s called cleaning up with a shop vac and it sucks.
View Paul's profile
Paul
#12 posted 07-16-2014 03:43 AM
So do I.
It s called cleaning up with a shop vac and it sucks.
- TheFridge
It sure “sucks less” when you don’t have to clean up.
Paul
TheFridge
#13 posted 07-16-2014 03:46 AM
Oh yes. It does. I effing hate it.
