Advice needed for hinges on thin stock
Forum topic by jeffswildwood posted 07-15-2014 12:12 PM 976 views 0 times favorited 4 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3610 posts in 2182 days
07-15-2014 12:12 PM
I am working on a shut the box game, with mitered corners, built from scrap, and need advice. I misjudged the size of the scrap and now have a lid that is 1/4 inch thick around the edges. It’s made with a new design due to my scrap stock being a bit small but came out beautiful! My problem is its too thin for the hinge screws. I had thoughts of mayby trying this to fix it-
1) cut some strips, miter and glue to the bottom edges of the lid giving me more thickness but a challenge to match the box.
2) shorten the piece on the back of the box 1/4 and add a 1/4 inch piece to the lid back bottom. I would have thickness but may look a bit weird
3) Top and back mount hinges not an option due to the way I made the lid.
I don’t want to make a new lid but would like input. Any help would be appreciated!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View SteviePete's profile
SteviePete
226 posts in 3508 days
#1 posted 07-15-2014 12:16 PM
push small hinges into small kerf on box side and box top. NO HINGES. S
-- Steve, 'Sconie Great White North
jeffswildwood
#2 posted 07-15-2014 12:23 PM
Steve, no hinges not an option but using a kerf to push in top sounds interesting, never done this.
View luv2learn's profile
luv2learn
2874 posts in 2508 days
#3 posted 07-15-2014 02:22 PM
Jeff, I have in the past run the hinge screws into the lid just shy of poking through the top to establish the thread pattern then I backed the screws out and ground off the tips and ran them back in. I used superglue or equivalent to ensure they didn’t come out. I know this isn’t a slick fix but I am not known for slick fixes….LOL.
-- Lee - Northern idaho~"If the women don't find you handsome, at least they ought to find you handy"~ Red Green
jeffswildwood
#4 posted 07-15-2014 02:30 PM
Lee, I thought of this, but once I mortise out for the hinge itself, not much room for grip. I’m thinking number one above and use a different wood for accent. just an alignment issue I will have to solve. I haven’t glued the bottom together yet so at least I have a pattern. Thanks for the tip.
