Building cabinet doors....
Forum topic by dakremer posted 07-15-2014 02:33 AM 2702 views 1 time favorited 75 replies Add to Favorites Watch
View dakremer's profile
dakremer
2661 posts in 2993 days
07-15-2014 02:33 AM
Hey guys,
I need some help building some cabinet doors. My wife and I just bought our first house (YAHOO!!) and we are planning on updating our kitchen cabinets. The cabinets themselves are in good shape, however the door style is not our taste. We also plan to paint the cabinets white. I bought some select pine boards from Menards and was going to make the new cabinet doors – I’m going to keep it simple, and modern….
something like this (all white)...
I am looking for some basic advice on building techniques. My plan is to cut all the pieces to length, use a router to cut a 1/4” dado along the interior/center, use 1/4 lauan for the middle, and connect the “frame” using dowels (with my doweling jig). Is this a good technique? Is there a simpler way? Should I use 1/2” ply instead of 1/4”?
I made a mock up tonight of one, and there is a twist in it which means it won’t sit flat against the cabinet. I’m thinking if I used 1/2” MDF instead of 1/4” Lauan that it would decrease my chances of the door being twisted/warped.
I did not plane or joint any of the select boards. (By eye) they seemed really straight, and I’m pretty sure my blade was at 90 degrees when making all the cuts, but it still came out warped.
Any advice would be awesome, as I told my wife I could build these…..and don’t want to let her down….again :) :)
-- Hey you dang woodchucks, quit chucking my wood!!!!
75 replies so far
View ShaneA's profile
ShaneA
6889 posts in 2500 days
#1 posted 07-15-2014 02:41 AM
I would vote for maple or poplar as the frame material. I bit more stable and harder. For the panels 1/4” MDF would be a smooth, cost effective choice.
View waho6o9's profile
waho6o9
8098 posts in 2479 days
#2 posted 07-15-2014 02:42 AM
Congratulations Doc on your home purchase!
Generally speaking the 3/4” face frame trade uses 3/4 inch
stock on the rails stiles and panels.
Measure the openings and add 1 inch to the width and height
that’s the size of your finished door.
Sometimes it’s more cost effective to have a shop that specializes in
doors and drawer fronts make em for you.
Good luck on your endeavors Doc and again congratulations!
dakremer
#3 posted 07-15-2014 02:49 AM
Here’s how I built the first one.
dakremer
#4 posted 07-15-2014 02:51 AM
I got select pine boards 50% off at Menards, and I also bought a 4×8 sheet of 1/4” Lauan (MDF backed) plywood. The costs comes to about $5-6 dollars in wood per door! I’m just painting them white so don’t want to spend the money on Maple or hardwood (even though it would be more stable and harder)
View MT_Stringer's profile
MT_Stringer
3152 posts in 3133 days
#5 posted 07-15-2014 02:57 AM
Make ‘em on the table saw.
https://www.youtube.com/watch?v=d-fCL-ZAVWs
There are more videos on You tube that cove the same basic steps.
Good luck.
Note: My doors don’t have any nails, just glue and clamps.
View NoThanks's profile
NoThanks
798 posts in 1431 days
#6 posted 07-15-2014 03:01 AM
EDIT: Looks like Stringer beat me to it.
Anyhu, probably the easiest and best for you.
-- Because I'm gone, that's why!
17517 posts in 1758 days
#7 posted 07-15-2014 03:11 AM
I use this router bit set. Works great for me. I just built 14 doors out of poplar and birch bead board. I started with 5/4 and jointed and planed it to measure 3/4” to make sure that it would be straight. I love the bit set and there are numerous profiles available. When you do the glue up, make sure the door is sitting on a flat surface while it dries.
dakremer
#8 posted 07-15-2014 03:12 AM
How about the twist in the door at the end? I’m trying to avoid jointing and planing every single board to get perfectly flat (i’m starting with 3/4 thick select pine boards)....
using 1/2 MDF for the middle would ensure everything is glued up nice and flat – no?
of course that adds to the cost of the doors.
I really like the table saw for cutting the dados….I was having trouble getting clean cuts with my router…
waho6o9
#9 posted 07-15-2014 03:16 AM
Great looking doors Bill, the bead board gives it
a nice look.
#10 posted 07-15-2014 03:17 AM
I have built doors with “straight” boards and had good success. If there is a slight bow, make sure they bow the same way as you make the doors. You can use adjustable hinges so that the door still closes flat on the handle side.
#11 posted 07-15-2014 03:20 AM
Thanks waho. These are for my aunt who lives in Atlanta. My mom and dad will take them from St. Louis and install. She will paint them white. She wanted a more country look.
runswithscissors
2641 posts in 1927 days
#12 posted 07-15-2014 07:30 AM
I learned the hard way that if the stiles aren’t jointed perfectly square on the edges, and the rails cut perfectly square on the ends, that it’s hard to avoid warping. Of course, warped panels can contribute to the problem.
I don’t think you need anything thicker than 1/4” for the panels.
View Sawdust4Blood's profile
Sawdust4Blood
397 posts in 2923 days
#13 posted 07-15-2014 10:04 AM
I have the same frame & stile bit set as Bill and also recommend them. One of the great things about that set for you is that it allows you to adjust the size of the slot to perfectly fit whatever panel material you use so they won’t rattle.
It doesn’t seem like poplar should be a lot more expensive than pine but I think that they will hold up better over time as cabinet door frames.
I also have to agree with runswithscissors in that I joint & plane everything and am meticulous with ensuring squareness. Even with that, you also have to make sure that you have a really good & flat reference surface to glue them up on. If your work surface isn’t flat, you could be inducing a twist when you glue them up.
You said that you’re looking for a modern look which I presume to mean the finished painted product needs to be smooth. If that’s the case, I would use poplar for the frames and 1/4 mdf for the panels. Lauan is a very open grain wood and I think that you’ll put a lot of time into sealing & sanding it before you get a smooth surface. Conversely, MDF will paint smooth with almost no effort.
-- Greg, Severn MD
View Jim Jakosh's profile
Jim Jakosh
20064 posts in 3007 days
#14 posted 07-15-2014 11:49 AM
If you’re paining them I think MDF for the panels would be better than the luan. Your design looks good but I think I would use poplar or maple for the frame. I’d prefer maple for wearability and dent resistance But I think pine would be too unstable. A lot of it you buy is not dried right and warps later. It can give you fits in door frames.
Jim
Smitty_Cabinetshop
15093 posts in 2520 days
#15 posted 07-15-2014 12:02 PM
Dak, I’ve had the Panel Warping Blues, too. For me the solution was in the clamp-up. Make double and triple certain the panel is flat and true when setting to cure and you should see a better result. Don’t overclamp, as that may build some internal stresses as well, that appear when the clamps come off. Hope that makes sense…
showing 1 through 15 of 75 replies
