motor wiring question
Forum topic by Jim Finn posted 07-14-2014 12:47 PM 1001 views 0 times favorited 12 replies Add to Favorites Watch
View Jim Finn's profile
Jim Finn
2688 posts in 3159 days
07-14-2014 12:47 PM
Topic tags/keywords: question scroll saw
I have an induction motor on my scroll saw that has a magnetic switch with a capacitor wired into the motor circuit. I want to eliminate this magnetic switch and install a foot switch. I need a step on /step off type switch, not one that has to be held down all the time the saw runs.(I have that switch) I am not sure if the capacitor is a run,start, or start and run capacitor. Any idea on how to rewire this? It is the capacitor in the circuit that has me stumped as to how to wire this to take the magnetic switch out of the saw circuit.
-- No PHD just a DD214 Website> craftingcouple.com
12 replies so far
View bigblockyeti's profile
bigblockyeti
5315 posts in 1958 days
#1 posted 07-15-2014 01:41 PM
Do you have a manual with a wiring schematic or is there one on/in the motor junction box? I’m certain this can be done but can’t offer any advise without a schematic or picture of some kind.
View mpsprunger's profile
mpsprunger
31 posts in 2098 days
#2 posted 07-19-2014 03:12 PM
The capacitor is used to start the motor in the correct direction. The capacitor causes a 90 degree shift in the current/voltage relationship. The current leads the voltage by 90 degrees. Without the capacitor it will sit and hum not knowing whether to turn CW or CCW.
Jim Finn
#3 posted 07-19-2014 08:31 PM
No schematic in the manual nor on the machine. I guess I need to take it apart and see how it is wired and make my own sketch.
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#4 posted 07-19-2014 08:43 PM
Just a foot switch to turn it on and off?
View nicksmurf111's profile
nicksmurf111
368 posts in 1688 days
#5 posted 07-19-2014 08:52 PM
Does the motor have a built-in overload? If so, there should be a reset button on it. What size is the motor, I’m not sure if they are required on small motors (less than 1/2hp).
Look for a schematic on the side of the motor or inside the wiring plate.
-- Nicholas
nicksmurf111
#6 posted 07-19-2014 08:53 PM
Did you purchase a foot swich yet?
-- Nicholas
Jim Finn
#7 posted 07-19-2014 09:04 PM
I want to use a tap on/ tap off foot switch. I do not want to hold the peddle down while I saw. The magnetic switch that is on the saw now requires a hold it down all the time foot switch. I want to eliminate that magnetic switch and wire in the foot switch I want.
nicksmurf111
#8 posted 07-19-2014 09:15 PM
Does the motor have a built in overload? Is the contactor seperate from the swich. If so, what make model is the contactor?
-- Nicholas
TheFridge
#9 posted 07-19-2014 09:20 PM
The foot switch you have is a momentary contact switch.
You need a toggle switch. That’s all you need. You may be able to find one that is a direct replacement.
TopamaxSurvivor
18423 posts in 3913 days
#10 posted 07-19-2014 10:12 PM
HI Jim, If you can post a picture of the mag switch and wiring, I can probably tell you what you need to do. Better hurry though, i just retired and I’m trying to forget this stuff ;-))
nicksmurf111
#11 posted 07-20-2014 12:54 PM
A momentary contact might just do it, but we need more info first.
-- Nicholas
View Redoak49's profile
Redoak49
3739 posts in 2226 days
#12 posted 07-20-2014 07:20 PM
HF has both type of foot switches and they seem to work well. I have had one for 2 years with no problems.
