Should gouges be as sharp as razors?
« back to Woodturning forum
Forum topic by ColonelTravis posted 07-14-2014 03:42 AM 2266 views 0 times favorited 21 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1770 posts in 1892 days
07-14-2014 03:42 AM
Topic tags/keywords: gouge sharpening
Bought a low-end lathe and some turning chisels then realized I had nothing to sharpen them with except flat waterstones and a grinder cotton wheel & compound. Don’t have a white sharpening wheel, the grinder isn’t slow speed, no grinder sharpening jigs, so all I’ve used is the cotton wheel.
I got the gouges sharper than they came, using my (very limited) set-up, and practicing on some walnut they seemed to work well. But I’ve never turned anything in my life, so are they supposed to be insanely sharp like bench chisel or plane blades? I’ve cut myself many times on plane blades, my gouges were not that sharp.
Also, with a plane, you can tell by your shavings whether your blade is sharp enough – how do you tell from woodturning shavings?
21 replies so far
View Woodknack's profile
Woodknack
11626 posts in 2378 days
#1 posted 07-14-2014 04:23 AM
Cleaner cut, less tear out with sharp tools.
ColonelTravis
#2 posted 07-14-2014 04:29 AM
Understood and agree. But can you get a curved chisel as sharp as a flat one? It’s easy working the convex side, but the concave side is a challenge.
View Paul's profile
Paul
721 posts in 1563 days
#3 posted 07-14-2014 04:45 AM
I take a router on a hardwood scrap and mold each side to the angles of my blades. Glue 1200 grit to each side and sharpen. This method works for me but I haven’t found anyone I know that uses it.
Paul
View Loren's profile
10390 posts in 3646 days
#4 posted 07-14-2014 05:44 AM
I find in the limited turning I do that real sharp edges decline
pretty fast but since the cutting is mostly from the side grain,
the important thing is angle of edge presentation to the work.
Grinding and buffing is generally adequate. The edge is still
going to have ridges that would make hand planing unpleasant,
but for turning these edges work okay.
You certainly should fool around with sharpening enough
that you can tell the difference between a shaving and
a scraping. Both have applications in turning but it your
cutting tools are scraping, some adjustment of the tool
or your turning technique should be considered.
View Arlin Eastman's profile
Arlin Eastman
4216 posts in 2559 days
#5 posted 07-14-2014 06:16 AM
It is not the same as a hand chisel
A wood chisel or gouge has wood passing by it several times a second so if the edge is razor sharp the end will not last as long.
Check Youtube for sharpening turning tools and you will see all use from 80 to 100 grit “K” hardness wheel. Some do stropping or touching up the edge. However, since a gouge can dull with in minutes the grinder is used a lot.
Many including me use a wolverine system with a varigrind jig and do a fast consistent grind everytime that way.
I really like how Lyle Jamieson does his turning and sharpens his tools. Following is a link to his YouTube
https://www.youtube.com/watch?v=UtNl1WvnG38&list=UU-EGwe-hMKrYtQGlwkLG-6g
-- It is always the right time, to do the right thing.
Arlin Eastman
#6 posted 07-14-2014 09:08 AM
Or This Link
https://www.youtube.com/watch?v=0zUph9zEjck
Both of them will get you to YouTube Videos of Lyle Jamieson
View Wildwood's profile
Wildwood
2305 posts in 2132 days
#7 posted 07-14-2014 12:49 PM
No, comparing turning tools to razors, bench chisels, or hand plane blades just not practical.
With turning chisels and gouges you depend upon bevel support to cut cleanly.
Shavings off a woodturning tool depends upon several factors. Goal should be a get off the tool surface and reduce amount of sanding needed..
Sharp vice dull tools
Angle of tool bevel
Dry vice wet wood
Wood species and other characteristics
Light vice heavy pressure, final light cuts produce finer shavings than heavy rough cuts.
-- Bill
View Nubsnstubs's profile
Nubsnstubs
1287 posts in 1728 days
#8 posted 07-14-2014 02:16 PM
Leave a burr on your gouges and scrapers….... When you lose the burr, sharpen and leave the burr again.
WW, what is your meaning of “vice”? I’never heard it used in woodturning…...... Jerry (in Tucson)
ColonelTravis
#9 posted 07-14-2014 02:40 PM
Thanks guys. I was impressed by the edge I could get on a flat stone, I’m sure if I get a slow grinder set-up it would be even better.
Wildwood – like Jerry, I’m stumped over “vice”!
View waho6o9's profile
waho6o9
8190 posts in 2575 days
#10 posted 07-14-2014 03:12 PM
Attach leather to the shape you want to hone and
strop away. It might take a while but it will be sharp.
Wildwood
#11 posted 07-14-2014 05:04 PM
With sharp tools able to cut wood smoothly with very little effort. With dull tools you tend to force the cut and exert a lot of effort forcing the tool to cut. Much easier to control your cutting with a sharp tool vice dull tool where you are forcing the cut.
That is how define sharp vice dull, and live by re-sharpen before tool gets dull!
-- Bill
View JamesVavra's profile
JamesVavra
304 posts in 3314 days
#12 posted 07-14-2014 05:09 PM
You can sharpen High Speed Steel (HSS) turning tools on your regular speed grinder. A finer grit wheel really helps though (I use a white wheel). They don’t need to be honed afterwards (but you’ll get a much better cut quality if you do). On dry wood or soft wood, you may have a lot of tearout with a tool straight from the grinder.
Nubsnstubs
#13 posted 07-15-2014 04:27 AM
Bill WW, isn’t that suppose to be “verses”?sp? instead of vice?......... Jerry (in Tucson)
View Ted's profile
Ted
2846 posts in 2209 days
#14 posted 07-15-2014 05:00 AM
Most of my little collection of turning tools are not very sharp and when I do manage to get a good edge on them, it doesn’t last very long. The one good quality tool I have is a Sorby 1/2” bowl gouge, which I would never take near my single speed grinder with 80 grit wheel. The other tools I use the grinder to shape the edge, then a diamond stone or oil stone to get somewhat of a sharp edge on them. I have resigned to doing a fair amount of sanding until I can afford more better quality tools and a better sharpening set up. Basically, it’s a bit more hassle with all the sanding, but I still manage to turn the shapes and get the finishes I’m after…. usually.
-- You can collect dust or you can make dust. I choose to make it.
ColonelTravis
#15 posted 07-15-2014 06:01 AM
After 4 disaster attempts (not the chisels’ fault) I turned my first handle, which fits great in the socket. Pretty blah design but I thought – just figure out how to make something round first, little Sorby Jr.
