Logs to lumber
Forum topic by Theartoftraditional posted 07-14-2014 01:41 AM 1136 views 0 times favorited 12 replies Add to Favorites Watch
View Theartoftraditional's profile
Theartoftraditional
3 posts in 1614 days
07-14-2014 01:41 AM
Topic tags/keywords: logs to lumber
I am getting into woodworking, and I was wondering what are the different ways to mill logs and how would I go about doing them?
12 replies so far
View Timberwerks's profile
Timberwerks
360 posts in 3362 days
#1 posted 07-14-2014 01:52 AM
View mahdee's profile
mahdee
4021 posts in 1969 days
#2 posted 07-14-2014 02:12 AM
My experience so far has been that you can buy $1000 worth of lumber form a sawmill. Or, you can spend $6000- $8000 on a do it yourself sawmill. You can have a sawmill, but you still have to get your trees from someone. But, if you don’t want to do that, you have to have heavy duty truck and a trailer. Then you need a place to store your wood for 1” per year. All in all, dedicated truck, trailer, insurance, registration, saw blades, paying for trees, spending the time to cut them and so on… You will end up with a bunch of wood 1/3 of which you will throw away. My suggestion, go to a sawmill and store the wood for one year per inch or pay for it to be kiln-dried or buy the lumber from a lumber store. It all depends on how deep you want to get into the trade.
-- earthartandfoods.com
TheWoodenOyster
1317 posts in 2136 days
#3 posted 07-14-2014 02:51 AM
MrJinx is correct when it comes to milling large amounts of wood, or even medium amounts of wood. If you are willing to do some very small-time milling, as in grabbing logs off of the curb or out of the back yard, you might be able to do some basic small milling with a good bandsaw. You would need to employ the use of a milling jig such as this one.
-- The Wood Is Your Oyster
Timberwerks
#4 posted 07-14-2014 11:13 AM
Here are some more milling photos. An Alaskan mill will cost $2000 – $3000 depending on how big you go, the trees I mill are free and taking the mill to the tree if needed is no problem since it’s very portable.
https://www.facebook.com/media/set/?set=a.10152428153536683.1073741868.126415221682&type=3
https://www.facebook.com/media/set/?set=a.10152542626406683.1073741870.126415221682&type=3
https://www.facebook.com/media/set/?set=a.10152443625751683.1073741869.126415221682&type=3
-- https://www.facebook.com/pages/Timberwerks-Studio/126415221682
View gfadvm's profile
gfadvm
14940 posts in 2891 days
#5 posted 07-15-2014 01:13 AM
I have milled lumber with a chainsaw mill (Alaskan) which is the least expensive method but a LOT of work and painfully slow.
I have milled smaller logs on a 17” bandsaw. Better, but still slow and resaw blades are expensive/don’t last long.
I currently mill logs with a Woodmizer LT15 manual mill I bought on CL. It is FAST, blades are inexpensive (and are resharpenable for $7 each!).
I have found the 1 year per inch of thickness drying “rule” to be totally wrong. Our lumber air dries to 12-15% in 3-4 months depending on the time of year. And our average daily humidity is 60%.
View WDHLT15's profile
WDHLT15
1792 posts in 2677 days
#6 posted 07-15-2014 12:05 PM
”I have found the 1 year per inch of thickness drying “rule” to be totally wrong.”
That is so true, but it is such an ingrained misconception that I have about given up on trying to correct it. I am sure that climate in some areas restrict drying to late Spring into early Fall because of ice and snow. Here in Georgia, wood air dries year round.
A good moisture meter takes all the myths and guess-work out of the equation.
View Monte Pittman's profile
Monte Pittman
30059 posts in 2539 days
#7 posted 07-15-2014 02:08 PM
I used the Alaskan chainsaw mill for 2 years. Worked fine, just slow. I built a sawmill for about $3000 about 1-1\2 years ago. I have cut about 7,000 board feet with it. Worth every penny. I love cutting my own wood. I hope to cut and stack another 10,000 board feet yet this fall.
Monte Pittman
#8 posted 07-15-2014 02:10 PM
The type of wood makes a huge difference for drying as well. Beetle Kill Pine is dry in 30 days, hardwood, much slower.
mahdee
#9 posted 07-15-2014 02:22 PM
I agree, every climate, storage methods and species of wood are a determining factor as to drying time. 1” per year is a general term used if you don’t have a moisture meter. Here is some additional information that might be of a use to you:
http://www.wood-database.com/wood-articles/drying-wood-at-home/":http://www.wood-database.com/wood-articles/drying-wood-at-home/
View summerfi's profile
summerfi
4036 posts in 1889 days
#10 posted 07-15-2014 02:28 PM
If you don’t want to invest the time and money others have mentioned, and if your logs are too big for a bandsaw, or you don’t have a bandsaw, then you should find someone in your area with a portable bandsaw mill and have them mill the logs.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
Theartoftraditional
#11 posted 07-15-2014 08:29 PM
I thank you all for your suggestions, I am thinking of using an Alaskan mill when I get the money, now the problem is termites in my log stash
gfadvm
#12 posted 07-15-2014 10:36 PM
You really can’t fully appreciate a bandmill until you have used a chainsaw mill for a while!
Those chainsaw mills are definitely for the young!
