How do you align your teeth on table saw dado sets?
Forum topic by Holbs posted 07-13-2014 06:19 PM 1428 views 0 times favorited 8 replies Add to Favorites Watch
View Holbs's profile
Holbs
1843 posts in 1997 days
07-13-2014 06:19 PM
I have both the Freud dado set and Forrest King dado set. One I use for general cutting of dado’s, one I will use as a premium when it comes time to do fine furniture dado’s.
I’ve always had trouble with my Freud dado’s because I “thought” I read somewhere all teeth have to be offset from each other. This left noticeable high/low valley’s. Then I tried having the outside and inner blade teeth aligned and each of the cutters offset. Now, perfection of a dado. Is there a safety issue of having it done this way, of outside and inner blade teeth aligned while each cutter teeth are equally offset? I really do not want to think I solved the dado valley puzzle if I’m missing a safety issue.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
8 replies so far
View NoThanks's profile
NoThanks
798 posts in 1496 days
#1 posted 07-13-2014 06:58 PM
I don’t align anything on mine. I just make sure the teeth next to each other aren’t hitting/rubbing each other.
Make sure the blade plates are flat against each other, (not riding on a tooth).
-- Because I'm gone, that's why!
View NormG's profile
NormG
5955 posts in 2971 days
#2 posted 07-13-2014 07:29 PM
Outside lined up, inside just so the teeth do not touch
-- Norman - I never never make a mistake, I just change the design.
View TheFridge's profile
TheFridge
9249 posts in 1453 days
#3 posted 07-13-2014 08:06 PM
Is the arbor on your saw threaded almost all the way to the flange?
4954 posts in 2461 days
#4 posted 07-13-2014 08:20 PM
I don t align anything on mine. I just make sure the teeth next to each other aren t hitting/rubbing each other.
- Iwud4u
Same here.
View firefighterontheside's profile (online now)
17960 posts in 1824 days
#5 posted 07-13-2014 08:28 PM
I agree with Iwud4u, I don’t align anything as long as no teeth are touching and the plates are flat against each other. I can’t see what the safety issue would be other than not having plates flat. When using only inner and outer they are certainly not lined up.
View Fuzzy's profile
Fuzzy
298 posts in 3956 days
#6 posted 07-14-2014 01:08 AM
All the blades in a dado stack swing in the same arc, regardless of their tooth alignment status, assuming the arbor is true.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
Holbs
#7 posted 07-14-2014 01:34 AM
might have to one day, find out if my arbor is true or not. or maybe i have had issues with perfect flat bottom dado’s because i have a bosch 4100 contractor saw and not a true cabinet saw.
View scoobydooo9r's profile
scoobydooo9r
187 posts in 3743 days
#8 posted 07-14-2014 05:01 AM
I just make sure it’s flat, but I did notice some messed up dadoes last time I used it. Maybe time to double check the ‘structions again!
-- I don't make mistakes, I make design challenges!
